2000 Executive 2.0 hdI 110 Heater Blower no Feed
Just bought this one (have 3 now) heater fan not working, have removed wiring from motor no feed at any fan speed, have checked fuses both ok. Anyone had this problem. Thanks Iain
- mjb
- Site Admin
Re: 2000 Executive 2.0 hdI 110 Heater Blower no Feed
Only thing I can think of (other than trying another control panel from a breaker's yard) is that the plug may have fallen out the back of the control panel, or you've got a wiring break between the panel and the fan
- puggy
- Resident Pervert
Also check the ignition switch these can become dodgy and
cut off the power supply
But there's power to the fuse?
According to Haynes, there's 3 fuses involved - MF12 & 13 in the engine fusebox plus F40, passenger fusebox.DandAAutos wrote:Just bought this one (have 3 now) heater fan not working, have removed wiring from motor no feed at any fan speed, have checked fuses both ok. Anyone had this problem. Thanks Iain
Failing that, blower controllers have been known to fail, though permanently on is understandably more common.
Welcome , BTW
Still no luck. Have fitted heater control unit to another car & it works fine. There is no feed to the grey & green/yellow wires that feed the control unit.
- puggy
- Resident Pervert
i had exactly the same problem turned out to be the ignition switch
wiring , with car running and blower turned on try wiggling the key
to see if it cuts in or better still remove steering shroud and try
moving the wires that go into the back of the switch !!
