Hello all I tried using the search but I dont think I asked the right question
Can anyone point out to me the obd socket location on a 2002 2.0 hdi estate? I looked around the fuses behind the panel by the drivers right leg but I couldnt spot it
cheers Al
As far as I know, the socket is located underneath the flat plastic trim near to the headlight level adjuster switch, to the rhs of the switch. A thin bladed screwdriver is needed just to pop out the panel.
