external temp sensor
tricky76
Post by tricky76 »
My external temp sender has done some weird things this winter firstly when i switch on my ignition the temp sensor says -2'c and when i start the engine it creeps up and stays around 8-10'c . Now i had had a problem with my battery keep going flat so i am wondering when you turn on and start the engine is probably getting a surge of voltage hence higher temperature or is it just the sensor on its way out :?
2.0 glx 16v
Busman
Re: external temp sensor
Post by Busman »
Hi.
This will almost always be the sensor itself buggered. I fitted a new one to mine which was dead easy. Not very expensive either. Do not try to pull the wires through the door harness, just cut and join them. Worth doing as the climate control uses it.
Richard.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
pugface406lx
Post by pugface406lx »
Hi ..i had same problem...except my temp reading went up to 49 degrees..!!!
As busman said..its easy to fix...the sensor is located in nearside fron door mirror...remove mirror unit from door and its located in there.
I did what busman said....I cut the wires in there and joined them together to new sensor using a solder gun and works a treat now ......as busman says it uses the climate in conjunction so needs to work properly.
Regards
Puggy
tricky76 wrote:Now i had had a problem with my battery keep going flat so i am wondering when you turn on and start the engine is probably getting a surge of voltage hence higher temperature or is it just the sensor on its way out :?
Sorry, I missed this one... twice :oops:
sounds like a dead battery, as car batteries have a finite life and once they go past that, they can't deliver the CCA needed
If you're worried your car's draining the battery when it shouldn't be, go to a Maplins branch. They can sell you a multimeter/ammeter and a suitable probe which fits in the fuse box. With that, you can diagnose exactly which system is eating your battery
406 electrics are surprisingly robust at this level though, and the chances are you may need a new battery. eurocarparts will sell you a decent one for minimal cash outlay
