02 406 hdi
mickeybo
02 406 hdi
Post by mickeybo »
The heater blower motor is not working on this vehicle with ign on getting battery voltage at red wire at blower motor with engine idling voltage at blower motor falls to
zero volts. This vehicle has A/C. Does anyone know of issues with this particular
problem. Any feed back greatly accepted
best Reguards Mickeybo
jasper5
Re: 02 406 hdi
Post by jasper5 »
It is more than likely a faulty heater control module (£50 odd quid at dealers), you can see the module wiring if you look to your right from the heater fan or follow the red wire to where the red wire terminates.
Check if you have live at the right side red wire with engine on, if so then the module is probably at fault.The module is held in by one screw and is about 3inches long when pulled straight downward.
A search on the forum will reveal lots of info on this subject, including problems with the ignition switch and burnt wires in the motor housing/connector.
