do you need an iso adadpter for aftermarket headunit?
on a 97 sri, or do the standard connectors plug straight into new headnut?
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
Re: do you need an iso adadpter for aftermarket headunit?
just need to swap the constant feed and the ignition feed round on the power iso connector, if one comes with the new hu then just gerry rig it so that you can swap back to the original hu if you ever sell the thing.
dead easy
dead easy
that sounds fiddly, is it not plug and play?
- DiscoPol
try it and see, if you think its too much like hard work, then halfrauds was made for you. enjoy
how do i swap them round? the leads pull out? thought theyre soldered
im not sure what you mean?
how do you pull them out to swap them? i just had a look and they feel like theyre gonna rip off if i pull to much
- DiscoPol
if your new HU came with an iso plug with flying leads then you can use that wired back to the original plug or just cut the two wires and swap em over then reconnect with either a soldered joint and insulation tape or some butt connectors or maybe even a screwed connection block if you will still have space at the back of the hu with such a thing.
its only two wires that need swapping over, its not like having to rewire the whole car
yh but i cant seem to pull them out, so gonna be messy lol
A pair of terminal blocks isnt too messy, wait till you get the new hu and then youll have a better idea what to do
