what freq shall i set HP filter to on headunit?
Re: what freq shall i set HP filter to on headunit?
the subwoofers annoying, some songs are fine, and others sound really bassy and like theyre killing the sub and go really low.
like some hip hop tunes you cant turn up as loud cos they get to bassy to low down the volume
ye it all depends on the song, and the sorce you will find mp3 sounds sh*t i never use mp3 i only use genuine cds from the shop, they sound much better
ive got albums from torrents, i thought theyd be good quality rips
its annoying i cant set it up like a stereo in a Club, they can play all music loud and the same and not distort
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
mp3s have too much removed to give good quality sound output on a system, they even sound sh1te in my landy with the factory amp and sub and after market hu.
sadly you will need a better quality source to get a better quality output.
but they shouldnt be more bassy/boomy just from being worse quality should they?
- highlander
- PowerFlow Shill
Depends on the bit rate of your MP3.
Normally your music ripping software will take the audio off the CD at 128 Kilobits per second (Kbps) at a sample rate of 44,100 Hz. You can hear the difference between this and a CD (difficult to describe, but there is a certain "mushiness" to some frequencies which is the result of the reduction in quality).
I have started only using 192 Kbps at 44.1 KHz, which is closer to CD-quality (uncompressed CD audio is 1,411Kbps), and is noticeably better (to my ear at least). The compression ratio on 128 Kbps is 11:1, where 192 Kbps is 7:1 - you capture the original waveform a lot more accurately. The downside is that your MP3s take up more space, but not so much as to make it unusable - it's a nicer balance.
If you buy music through iTunes and the track they offer you is also available as an "iTunes Plus" track, get the iTunes Plus version. Yes it's a bit more expensive but 1) there's no DRM and 2) the bit rate is higher (either 192 Kbps or 256 Kbps). They also use AAC which is less of a lossy compression format than MP3 is.
my songs are at least 192kbs tho, and the others are VBR files which are supposed to be better arent they?
- highlander
- PowerFlow Shill
Unless you use a true lossless audio compression format (i.e. FLAC or MPEG4-ALS) you're going to get sub-CD-quality sound. Variable Bit Rate is supposed to help strike a balance between file size and audio quality by upping the bit rate for complex sections and lowering it for less complex sections. This has a negative effect on subtle harmonies, which are often dropped in quality or (irritatingly) omitted entirely.
I'm glad you're not using 128 Kbps bitrate or (gasp!) lower! I just mentioned it because most people tend to leave their CD ripper software on the defaults and either don't have a keen enough (or a discerning enough) ear to notice/care, in which case upping the bit rate is the first thing to try.
What I don't get is kids that listen to music using the speakers built in to their mobile phones (irritatingly, on buses, trains, or in other public places). Sounds tinny and crap; I can't bear to hear it!
also weirdly, i downloaded tinie tempahs album, and one of the tracks is fine when i play the file on the laptop, but on my headunit its turned it into a dubstep version, really weired, it sounds like its ment to be a dubstep version, but its obviously the bitrate playing up, isnt that strange? it plays normally on laptop
thats probably because your laptop speakers cant re-produce some frequencys with being very small speakers
no but you can tell its not all slowed down like in the car
heres a pic of my boot, subs are currently not fitted due to a water leak im fixing, should be back in 2moro ,
oh bt w im using an Alpine ported box, so do i need different settings for this? or is 80hz still fine? its a proper alpine box so is tuned right
