yes , 4 x 5meter lenths
cos each of the 4 is double,
how to remove door molex *PICS*
Re: how to remove door molex *PICS*
my amp only has 2 channel connections tho, do i just double up each terminal?
just remembered im gonna have to run another set of RCA's if i amp my speakers, im not gonna have room down the passangerside, and had trouble with the drivers side trim
so do i just double up on my 2 channel terminals then?
is there no way to make the headunit run the rear speakers and the amp just run the fronts?
hi, yes if you double up that lowers the load resistance down , car amps run at 2ohm and 4 ohm,
conect 1 set of speakers to a 2 channel amp thats 4 ohm
add 2 sets of speakers to a 2 channel amp (double up the terminals) and thats 2ohm
2 ohm makes the amp produce more power
but 4 ohm is more efficient
my amp is 2x 70w rms at 2 ohm i think, so ill be getting 35 rms each then?
yes it divides the power to the 2 speakers,
