dumb question here,
just bought a cd radio from a scrapyard.
plugged it in got the loads of beep noise very iritating, cd tried to load and spat it out,
the chap said il get it coded for you its no problem
itold him there vin coded, he said no there not they are half coded?
he rekons he needs to put the vin number in from the car its come out of, itold him it needs the vin putting in from the car its going in (mine)
I know on D9 406s, the stereo needs to be coded with the VIN of your car (the car the stereo is going into). If it isn't coded to your car, then the stereo will work just fine, but will beep loudly every few seconds to annoy you.
On D8s, I believe, the stereo itself had a key code you had to enter into it any time you disconnected and reconnected the battery. The code was unique to the head unit, not to the car, though you could change the code you use for security purposes.
Not sure which way it'll work on the Picasso, but I reckon you're right - you would need to treat it like a D9 406 stereo - VIN coded with the VIN of your car, so that the BSI can check the VIN coded on the stereo matches with the VIN coded in the BSI.
