JBL or no JBL on an SE
blzeebub
Post by blzeebub »
Morning All,
Ive got a 53 plate 2.2HDi SE and im looking to change the HU and im trying to work out if ive got a JBL amp or not. Its an RM2 with a CD Changer and Sat Nav and as far as i can tell its supposed to be in the boot next to the CD changer or the Sat Nav. I can find them but cant see an amp. Can anyone tell me if its definitely got one or not and if so where it is!?!
Cheers
Nat
2003 2.2 HDi SE in Samarkand Blue replaced the good ol' 99 2.0 HDi 90 GTX. Now i know what the pedal on the right does!
midsmike
Re: JBL or no JBL on an SE
Post by midsmike »
Hi mate if its got the amp it will be on the right as u look in the boot or u cud just take the door speaker out and see if it says jbl on the bk
grasmere59
Post by grasmere59 »
Don't quote me on it but i think it was an option on the SE so you might not have it.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
ServiceBox might tell you if yours had it.
Also, the JBL amp was only ever fitted along with JBL speakers, I believe - if your speakers aren't JBL, the amp won't be there. The speaker grills on the rear parcel shelf had the JBL logo on them (on the Coupes with "SE" and "Silver & Black" trim, at least; I believe the same was true for the Saloon too).
blzeebub
Post by blzeebub »
Thanks all, ill do a check on the speakers first and see what that gives me. It would make life easier if it doesnt have and amp though!
Can any one tell me how to get service box to give you a spec of the car from the VIN?
Cheers
Nat
B->
Sign up to http://public.servicebox.peugeot.com/ (just make out you're an independent garage). :wink:
If you don't get anywhere with that approach, PM me your VIN & I'll look it up for you.
Just bend back the carpeting on the right hand side of the boot (remove one or two plastic studs first) and you'll see it (or you won't :( ) this will only take 5 minutes.
...always assuming it's a saloon. :roll:
Doggy wrote:...always assuming it's a saloon. :roll:
I see your Holiday has done nothing to calm your sarcasm, the weeks' rest has probably done your pin-sharp Brain some 'good' albeit at our expense and embarrassment.
Anyhoo, surely the JBL Amplificator will be behind whatever you get in the Van version and on the same side as the proper model?
blzeebub
Post by blzeebub »
Another hunting session is on the cards for this weekend.... and yes it is a saloon!
B->
blzeebub wrote:yes it is a saloon!
Yes! eat that Doggy :lol: :lol:
Welly wrote:on the same side as the proper model?
The Coupe has the JBL amp behind a flap on the left side of the boot, just behind the CD autochanger. It's an unlabelled black ridged box (the ridges, I would assume, dissipate heat more efficiently (a heatsink)). The right side of the boot hosts the sat nav unit (again, hidden behind a flap).
Is this the same way the saloons and estates have their amps (etc) set up? Don't see any logical reason why they'd be set up any differently.
Welly wrote:I see your Holiday has done nothing to calm your sarcasm, the weeks' rest has probably done your pin-sharp Brain some 'good' albeit at our expense and embarrassment.
The premium shooting brake has this apparatus secreted behind an access panel on the right, one's CD changer being similarly located on the lefthand side of the vehicle. A gentleman simply does not disturb the upholstery to access this equipment.
And don't call me Shirley!
why not ?
shirley :supafrisk:
(only joking )
