Weedy HDi 90
Re: Weedy HDi 90
yours is the best machine about, a remapped 2.2 180bhp must be scary.
Re: Weedy HDi 90
What does this remap Entail ?
is it just a plug in they do and add software,?
Mines got a chip thing in under a black box with a wire coming off it its not a standard component,
im just wondering if mines been modded as its very Quick for a 2.0 hdi
Re: Weedy HDi 90
youve got a chip, and the members here who know their stuff dont recommend them (i dont know my stuff) apparently they fool the cars ecu into overfuelling or something which apparently is bad. A remap is essentially reprogramming the cars ecu ie the bit that controls how much diesel comes in at specific revs this program is called a map hence remap.
- highlander
- PowerFlow Shill
Re: Weedy HDi 90
Yes, they basically electronically reprogram the ECU (the engine management computer) and changes various parameters, the net result of which is a greater power output (higher HP rating) and increased pulling power (higher torque rating). If done properly, it is also possible for the remap to cause the engine to be more fuel-efficient.lozz wrote:What does this remap Entail ?
There are various tuning boxes which fit between the ECU and the engine, and are designed to change the air pressure from the turbo and the amount of fuel being burned by the engine to create more power. However, the main drawback behind this is that the tuning box is not privy to the same sensor inputs as the ECU gets - so it is a less effective tool, and will probably just cause the engine to constantly burn more fuel - it's true that this will increase the overall power of the engine, but it will cause fuel consumption to go up for the most part, and the engine will probably end up registering anti-pollution faults more often.lozz wrote:Mines got a chip thing in under a black box with a wire coming off it its not a standard component,
Furthermore, VOSA have confirmed that the next revision of the MOT will make cars fitted with these after-market "piggy-back" tuning boxes an automatic fail. Remapping the engine ECU is invisible to MOT testers, and VOSA will not be able to outlaw these as they are pretty much impossible to check for.
I'd get shot of the tuning box and get the car professionally remapped instead. The best part about getting a custom remap done on your car is that you can have it customized to your driving style. If you do a lot of towing, be sure to tell your remapper because they can change the parameters in such a way as to help towcars.
Re: Weedy HDi 90
yip an eco remap £250 you get 136 bhp and apparently your fuel consumption drops. And if you dont like it they remove it for free, and give you a refund.
Re: Weedy HDi 90
Yeah, i've got a cd containing all the original parameters so can be changed back if required (given the right leads and software of course)
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: Weedy HDi 90
would the pp2000 lead be considered the 'right lead' if you had the software could you remap through it.
Re: Weedy HDi 90
Nope. You need a Galletto 1260 / KWP2000 or simular
Re: Weedy HDi 90
another lead, but whats the difference, they all work through the usb port of the computer, surely its down to the software.
- rwb
Re: Weedy HDi 90
So its either a re-map (and de-cat) or
Patience is a virtue. Apparently.
The latter being more compatible with my budget.adamr8965 wrote:...just chug up the hills...
Re: Weedy HDi 90
that sort of BHP in a diesel is sh*t hot better than petrol with the extra torque,FarmerPug wrote:yours is the best machine about, a remapped 2.2 180bhp must be scary.
my mate has a golf gt tdi 170bhp , i love it , sh*t load of power
- jamjar1383
Re: Weedy HDi 90
a decat and de-egr wont cost hardly anything and will help the engine rev more freelyrwb wrote:So its either a re-map (and de-cat) or
d9 hdi 90 rapier estate
Re: Weedy HDi 90
how do you de-egr.
