D9 Headlight Removal Guide
Re: D9 Headlight Removal Guide
check that, twould be worth knowing.
Perhaps for one of the members with the ability to change the title and so forth ie a moderator, could thou make the headlight removal bit seperate than this condensation bit?
FarmerPug wrote:thou
:shock:
Yay verily I hast done this on the day of yester, thou dolt.
I wonder if that super-absorbent stuff they fill nappies with would work?
FarmerPug wrote:check that, twould be worth knowing.
^ aye the stuff iused on the lens, was Simonz Hard wax,
its Cheapo ish @ a fiver but tis good stuff. 8)
at 5 it seems good value.
Country pugs one of taking out a bulb and leaving the lights on is a good one, then make sure all the seals are good, and the black tube for letting air out is clear.
a few important bits of info are missing and im not sure how to fill them in so answer these questions:
- is the full beam the inner or outer bulbs.
- is them philips extremes for full beam or dipped
- how to align the lights yourself
FarmerPug wrote:a few important bits of info are missing and im not sure how to fill them in so answer these questions:
Q : - how to align the lights yourself?
A: its not possible to do this your self its a garage job only,
Guesswork just results in a mot fail normaly :(
on the issue of getting the foglights out here is a picture of one out:
the top bolt is the issue.
