Offline for a bit
Re: Offline for a bit
supafrisk wrote:Just to let you all know, my p.c. is very poorly.
Internet explorer keeps crashing, windows explorer keeps refreshing, Dr Watson keeps crashing in debug mode and then just to add the icing on the cake, I get the whole lot crash and the dreaded blue screen of doom which of course only flashes up for a second before the computer reboots so I can't even read what the problem is.
Oh and I get a pop up telling me my windows virtual memory is low and programs may not run whilst it is correcting the problem!
My hard drive is 30% full :shock:
I've checked it with Macafee, panda and trend micro housecall, and apart from a couple of the usual trackers and adaware the pc is clean.
I've deleted programs I don't use and defragged away.
I think the problem may lie either in the windows registry or a problem with it running java and macromedia, if I attempt to play Isketch online, that's when it starts shutting stuff down.
I have backed up everything I need tonight and someone must be smiling, cos I just bumped into a nice man with a fit bum *cough*. It so happens I installed his printer drivers last week :oops:
He is lending me his original XP and service packs so I *may* just wipe the lot and start again...
There's only one snag :oops:
I think you have been looking at mens willy's again on the Internet Porno sites and your computer has a viral infection, go to the doctors with it immediately. :D
GeordieBoy
Post by GeordieBoy »
2 options, try this 1 1st:
1. Goto reinstall windows, you get an option to Repair or Install, click Install, then next screen says you already have a copy of Windows and asks again do you want to Repair or Install, this time click Repair. It will then Repair your Windows Installation Files keeping all your Programs and Files intact. (You must click the Install option at screen 1 tho, as if you click Repair then it does not repair all files).
2. Do a complete Re-install which will wipe your harddrive and then you will need to install all your Programs and you will lose all files.
Vehicles I own:-
Foxy
Forum Admin<BR>Know it all
Post by Foxy »
http://www.ccleaner.com
download and run that before you try anything drastic
Used to own the finest 406 in the UK - RIP
