Dull Soldering
Dull Soldering
I know what it is now, when a crack is in the solder.
But the thing is how do you get rid of it, every time i hit solder with my soldering iron its nice and shiny when its molten but dries quite dull looking.
The tip gets cleaned in the solder iron spongue, what am i doing wrong.
Re: Dull Soldering
FarmerPug wrote:I know what it is now, when a crack is in the solder.
try a differnt type of solder .
have a read of this
http://www.ami.ac.uk/courses/topics/0170_wsp/index.html
Re: Dull Soldering
crack = dry joint
just heat the solder iron up and smooth it off. very easy frank .
as loazz said use different solder if that one is drying dull. altho it probably wont make a difference if its shiney or dull :?
Re: Dull Soldering
+1
But, if you can't see it - who cares?
sirwiggum
Re: Dull Soldering
Post by sirwiggum »
Unless it affects operation, or you are displaying your PCB, if it works then its fine :)
Some flux might help to stop the metal contacts getting discoloured.
Re: Dull Soldering
i just always thought it cant be dull looking for it to work right.
flux then the solder paste, do you just smear it over the joint?
Re: Dull Soldering
Just use flux cored solder, if it's in a bubble across the joint, rather than two islands, it should be fine.
Re: Dull Soldering
i bought solder today at the hardware shop, leadfree this time, and it makes a nice shiny solder now.
Re: Dull Soldering
That stuff's for soldering pipes together that supply drinking water, it does the job but it melts hotter and you risk damaging circuit boards using it.
Re: Dull Soldering
no its still standard electrical solder, just lead free. Ive seen plumbers solder its much thicker.
Re: Dull Soldering
Fairy nuff, that's a new one on me. I can't see why they needed to make that, I was using the lead stuff for many years and it never did me any harm. Wibble wobble I'm a lawnmower.
Re: Dull Soldering
i was taught in school that the gas isnt good for you.
Re: Dull Soldering
It's mainly the fumes from the flux, especially if you have an existing condition such as asthma.
Re: Dull Soldering
Ah right I've had a fair gulp of solder fumes and never felt anything apart from stinging eyes one day
