Trailer Licence
Trailer Licence
I have a car with a tow bar, plenty of pulling power and access to a number of trailers and a transporter but i cant use them legally because i dont have the trailer licence.
Has anyone done the trailer licence, i sort of need one, but what puts me off is having to reverse a trailer, i can do it but really slowly.
Re: Trailer Licence
frank do not worry about it mate.
theres no way on this earth a police officer will pull you over and ask to see your trailer license.
i use to always tow and i dont have that feature on my license.
it wont happen
it wont happen
Re: Trailer Licence
i bet they would here, the police here are quite good at unexpected checkpoints. Id like to have it because if they did give me points id be fecked insurance is expensive enough without anything else.
Re: Trailer Licence
I dont know how old you are but if you passed your driving test before the 1st of Jan 1997 then you already have it.
Heres the guff http://www.direct.gov.uk/en/Motoring/Dr ... DG_4022547
Re: Trailer Licence
im 19 passed the test in 2008 so well after the 1997 thing.
i need it more now for carting the jeep about the place, or for getting old cars for breaking, its too unreliable my da or uncle if they can do it.
Re: Trailer Licence
Lucky for me i did but i am told that it is a bit of a bastard to pass. I drive all day every with a trailer of some sort so a little advice would be to use a good size trailer as its far easier to maneuver and see in your mirrors. These tiny little box trailers you see outside halfords for instance will be a bastard to use and jackknife dead easy.
Re: Trailer Licence
They wont give you points they will just take it off you or give you some Ear ache,FarmerPug wrote:i bet they would here, the police here are quite good at unexpected checkpoints. Id like to have it because if they did give me points id be fecked insurance is expensive enough without anything else.
You will Get a Tug with abig car trailer its un avoidable there pulling them in looking at the stamps to see if theyve been Ground off /plated over,
Buy a cheap car transporter ford/transit etc problem solved then
Re: Trailer Licence
i dont understand whats to be ground off?lozz wrote: You will Get a Tug with abig car trailer its un avoidable there pulling them in looking at the stamps to see if theyve been Ground off /plated over,
i dont have a trailer i just use my uncles trailer, or my cousins car transporter trailer.
Re: Trailer Licence
Trailers have Chassis number like a car,FarmerPug wrote:i dont understand whats to be ground off?lozz wrote: You will Get a Tug with abig car trailer its un avoidable there pulling them in looking at the stamps to see if theyve been Ground off /plated over,
iwas saying there pulling them in to check all is above board,
Iwasnt saying you shouid take an angle grinder to the trailer or anything
The plod are looking for trailers thats a bit Warm thats all iwas saying -hence why there stopping people with them
Re: Trailer Licence
ah thats no problem my uncles trailer is definatley ok, i went with him the day he got it from the shop and it was new.
Re: Trailer Licence
Im not saying it isnt,FarmerPug wrote:ah thats no problem my uncles trailer is definatley ok, i went with him the day he got it from the shop and it was new.
just comenting on why there picking on pulling in trailers thats all,
Re: Trailer Licence
ah the police, they just pull in anything that looks different, modified cars for example get pulled in all the time, you have talent beside you they will pull you in, if you havent got 2 disks one for mot one for tax they will ask many questions.
Re: Trailer Licence
ah you have 2 discs ? thats sad,FarmerPug wrote:ah the police, they just pull in anything that looks different, modified cars for example get pulled in all the time, you have talent beside you they will pull you in, if you havent got 2 disks one for mot one for tax they will ask many questions.
we only have one,
that used to be ok as a Beer mat or something simalar colour used to do
iknew someone that stuck a peice blue card board off a Gillete mach 3 shavers in the tax disc holder,
police tugged him and let him off for his sheer cheek
iused to notice cars seemed to run better years ago with no road tax strange that
Re: Trailer Licence
A quick google found this,
If you can practice off road then wide trailers can be seen in the mirrors, and long trailers don't swing as fast, so you can learn to reverse without constantly jackknifing.
If you are using a small trailer then put a broomstick on the centreline of the trailer at the front and back of the box, as 'sights', and keep them in line as you reverse to go straight,
or use them to gauge where the trailer is going. Lose the front stick, or put them in the rear corners as you improve. Once you can reverse a small trailer without any aids there's no problem.
Going forwards a short, narrow trailer will just follow the car, a longer or wider trailer will need more care at corners, junctions and gaps. Remember to adjust your braking distances and observations.
Training/testing for cars around here seems to be with the small halfrauds 'tin' trailers.
stealthe
TBH it sounds a pain in the back****, but if you are towing and not licensed then your insurance is invalid also. You risk losing your car, not just points and higher premiums.What does the test consist of?
The test is conducted by the LGV examiners at the lorry test centres, taking about an hour to an hour and a half. The first part is off road, comprising of a reversing manoeuvre; a controlled emergency stop and disconnect/connect the trailer. The on road part is a full driving test and you will be expected to drive to a very high standard. Particular emphasis is placed on use of mirrors, forward planning, general observations, road positioning and consideration for other road users.
stealthe
Re: Trailer Licence
halfords trailers they are just samples of a real trailer
