Redex £2 a bottle @ tescos
Catflem
Post by Catflem »
They have both the petrol and diesel versions available.
The only drawback is that the instructions state that it should be added to a full tank of fuel......... I can't remember the last time I filled up, and its going to be a bloody long time before I do so again :cry:
Bailes1992
Re: Redex £2 a bottle @ tescos
Post by Bailes1992 »
Also got this deal on in Asda! I run my lawnmower on the stuff at the moment :lol:
Ijust thrown the whole bottle in with half of tank,
it hasnt done it any harm, wouidnt do that on a petrol car tho,
ithink it shouid of been half of bottle to a full tank, :oops:
the Redex as worked a treat on mine, iwont be using it for another 6mths or so tho,
they rekon it can knaker pumps if used frequently, :frown:
HimBigChief
Post by HimBigChief »
Does this have any noticeable effect on diesels (both HDI and TD)? In other words, has anyone actually noticed any more power or better fuel efficiency after sticking a bottle of this stuff in? If they have, then I may well invest in a few bottles as I cover some serious mileage every month.
Image Image
plod
Post by plod »
Bailes1992 wrote: I run my lawnmower on the stuff at the moment :lol:
Is that the new name for the Focus then Sam :lol: :lol:
1999 D8.5 HDi GLX - Sold :(
HimBigChief wrote:Does this have any noticeable effect on diesels (both HDI and TD)? In other words, has anyone actually noticed any more power or better fuel efficiency after sticking a bottle of this stuff in? If they have, then I may well invest in a few bottles as I cover some serious mileage every month.
inall honesty, mine was down in power with the red ex in,
but now the tank as emptied and re filled its made a big diffence, its alot smoother
id use it again but once every 6mths or before a service just give it a clear out
Bailes1992
For a diesel use either Millers Eco max or the best additive I've ever used is oridinary, low ash mineral two stroke oil! 250ml per tank.
i used a rather conservative amount back when i used to fill the tank, a capful, no difference was noticeable, lozz stated a better dosage which i shall put into the car the next time i go to put in some diesel, but how much should i put in with £25 of diesel ie about 18 litres.
Catflem
Post by Catflem »
FarmerPug wrote:i used a rather conservative amount back when i used to fill the tank, a capful, no difference was noticeable, lozz stated a better dosage which i shall put into the car the next time i go to put in some diesel, but how much should i put in with £25 of diesel ie about 18 litres.
The correct doseage is half a bottle to a full tank, but bearing in mind that tanks vary wildly in size across different manufacturers, I don't think that the exact doseage is critical..
Give or take a bit, 18 litres would be about a third of a tank, a third of a half is a sixth....... so if you put in a 6th of a bottle you shouldn't be far wrong (250ml /6 = 42ml).
It says on the Redex bottles that a typical tank is 50 litres.
Any time I used it, it was half a bottle in a full 70 litre tank.
a quarter of a bottle shouid be enough on £25 worth of fuel mate,.
dont expect the mpg to increase tho, its the After effect of the Redex you will benifit from,
id say around 2-3 mpg loss will accur whilst running the redex through it but once its all been run through it you will notice a big differnce,
dont use it often once every 5-6mths is good enough irekon :roll:
