How your car left the factory
If anyone wants to know what there car left the factory with, if you post or pm me your vin number myself or indeed anyone else with servicebox can give you all the details.
Re: How your car left the factory
Having a slow day?
does it showsteve_earwig wrote:Having a slow day?
for the record this is the type of info
Vehicle characteristics
Vehicle family 406
Build code 07990 89 4 0282
Warranty Start Date 31/01/2000
Engine serial number 10 KJM5 2001084
Gearbox serial number 20 TP16 0018504
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 406
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL SELECTION PACK
ENGINE INJECTION XU7JP4
TRANSMISSION Auto gearbox AL4
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR ETH - CHATEAU GREY PAINT
INTERIOR TRIM TYPE DUNE VELVET "BM"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) Auto gearbox AL4
ENGINE (TYPE) XU/XUD
OTHER BADGE WITHOUT FULLER BADGE
BADGE ST
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 20X16
Fuel supply-Engine
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITH PRE-FILTER
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER WATER/OIL EXCHANGER ON GEARBOX
FUEL TANK INSULATION FUEL TANK INTERIOR INSULATION
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
VEHICLE TECHNICAL DEPOLLUTION L3 VEHICLE TECHNICAL DEPOLLUTION
FAN 2 FANS , 2 RATES , IMPROVED
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
Gearbox Transmission
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 23 X 73
WHEEL STYLE STEEL WHEEL
CLUTCH WITHOUT CLUTCH
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
TYRE (SIZE, TYPE) 185X70X14 H TYRES
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE Auto gearbox AL4
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
POWER STEERING FLUID COOLING SYSTEM WITHOUT COOLING
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
Body fittings
HORNS HORNS-HARMONY
AERIAL LONG ROOF AERIAL
WIPER ARM FRONT BLADE WITHOUT DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR W/O CHROME RING
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS WIDTH = 50
WHEEL EMBELLISHER (STYLE) SILEX STYLE 8 HOLES 14 INCHES
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
INDICATORS WITHOUT SIGNALING LIGHTS
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET WINDSHIELD WASHER JET W/O DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT FULLER FUNCTION
EXHAUST TAILPIPE TRIM W/O EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN GLASS (TYPE) NO HEATING WINDSCREEN
WINDSCREEN WIPER INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BUMPERS WITHOUT EMBELLISHER
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES DOOR MIRROR AND HANDLES BODY COLOUR
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) LAMINATED QUALITY 2
Interior fittings
ANTI-THEFT ALARM ELECTRICAL CONDITIONING
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMREST WITH REAR ARMREST
INTERIOR ALARM ALARM FORGET LIGHTS
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITHOUT LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
AIR CONDITIONING MANUAL CONTROL CAR HEATER
SPEED GRADUATIONS GRADUATION KMS/H
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
DASHBOARD EQUIPMENT DASHBOARD LARGE GLOVE BOX COVER, WOODEN TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM BOOT TRIM
DOOR TRIM WITHOUT WOOD EFFECT DECOR WITHOUT LEATHER
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITH CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS WITHOUT REMOTE RADIO CONTROL
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITH SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
HANDBRAKE WARNING LAMP PARKING BREAK INDICATOR
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE W/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 2 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG NO PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) WITH REAR SHELF LOUDSPEAKER GRILLE
ON-BOARD COMPUTER NO COMPUTER
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
RADIO RECEIVER RADIO EQUIPMENT
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
RHEOSTAT RHEOSTAT
AIR CON./TEMPERATURE REGULATION WITHOUT REGULATION AIRCON/TEMP
STORAGE (OTHERS) FRONT SEAT STORAGE + 2 BOXES IN BOOT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
LIGHTING TIMER WITHOUT TIMER
INTERIOR PROTECTION WITHOUT INNER PROTECTION
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
ANTIPOLLUTION MALFUNCTION WARNING LAMP BAD FUNCTIONING ALARM
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL,4 BRANCH
Electrical
ALTERNATOR ALTERNATOR 120 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L1 250
STARTER MOTOR STARTER MOTOR CL 3
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS DUSTY ATMOSPHERE
FIRST AID KIT WITH FIRST AID BOX
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS DOOR WITH REINFORCEMENT
SET OF KEYS 1 I/R PLIP KEY + 1 PRINC UNIQ KEY
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Vehicle family 406
General information
PRODUCT TYPE CAR
VEHICLE FAMILY 406
BADGE ST
Fuel supply-Engine
RHEOSTAT RHEOSTAT
ABS WITH ABS BRAKES
Body fittings
HORNS HORNS-HARMONY
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
Electrical
HORNS HORNS-HARMONY
Miscellaneous
Here's how my old 406 left the factory:
ATTITUDE - WITH ATTITUDE
EMBARRASSING LIFT PUMP FAILURE - WITH LIFT PUMP FAILURE
SPURIOUS MIL WARNINGS - WITHOUT FINANCIAL GAIN
CURIOUS DIESEL ODOUR - WITHOUT TRACEABLE DETECTION
- sirwiggum
My 406 left the factory with half the rustproofing forgotten about.
And Claude's chewing gum used in leiu of an engine mount.
The Honda left the factory in Maryland, USA
Oh bejesus, a Dunkin-Donuts carsirwiggum wrote:The Honda left the factory in Maryland, USA
- sirwiggum
Certainly explains the cupholders everywhere!Welly wrote:Oh bejesus, a Dunkin-Donuts carsirwiggum wrote:The Honda left the factory in Maryland, USA![]()
You normally find that USA-intended cars have, shall I say, more 'generously proportioned' seating
- sirwiggum
Suits ample framed persons like myself
Welly wrote:Here's how my old 406 left the factory:
Mine was simular:
UNDENTED PANELS - NOT AVAILABLE
STEERING - UNVARIABLE POWER STEERING WITH INCURABLE WOBBLE
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS/CRAPPY HANDBRAKE
NAVIGATION - WITHOUT SATELLITE NAVIGATION
WINDSCREEN - ATHERMIC, (THEREFORE WITHOUT AFTER MARKET SATELLITE NAVIGATION EITHER)
