Hi guys, headlight bulb has blown on my LT35.
The the dipped headlight has a metal cover over it, which has fallen off into the lens.
There is metal clips that hold the glass to the plastic surround, could i pop these off and then re-fix the cover back in with no issues?
quick good hasnt helped!
Headlight disassembly
Re: Headlight disassembly
check there isnt a bead of silicone behind the glass,
if not then the glass shouid come off once the metal clips are removed,
