Be quick, this is for a limited time only.
To get this discount, all you need to do is use the code: TITAN at checkout! Unfortunately, your forum discount cannot be used in conjunction with this.
One of the most popular choices in this range is the Fuchs Titan Race Pro S 5w-40. Originally, 5 litres of this was £47.95 but with the discount it is now £40.76! Another very popular viscosity is the Fuchs Titan Race Pro S 10w-50 - this was £51.95 for 5 litres, and is now £44.16!
Fuchs engine oils meet the latest and most demanding specifications set including the latest ACEA C1, C2 and C3 low SAPS approvals. Opie Oils are official distributors for this prestigious brand, so if your vehicle is getting fast road use, track days, or competition use, we've got you covered whatever your set up or level of modifications!
Every oil you will find in this Titan Race Pro range including the Pro S and Pro R oils, is a fully synthetic, ester based high performance engine oil providing optimum protection for extended engine life and reliability - with the added bonus of having 15% off! Simply click HERE to see the entirety of what we have to offer, including 0w-20, 5w-30, C3 5w-30, 5w-40, 10w-40, 10w-50, 10w-60, 15w-50 and even 20w-50 which is perfect for a classic performance engine that has been rebuilt. Once again, that code is: TITAN
There is an array of benefits to be gained from using these fully synthetic ester based oils, some of which include:
- Enhanced anti-wear properties
- Outstanding temperature protection and cold start characteristics
- Suitable for use in turbocharged and normally aspirated diesel and petrol engines
- Increased fuel economy
- Reduced emissions
- Ester content creates surface-active layer, meaning a thin layer of oil on the surfaces at all times
Looking at getting your gearbox or differential oil changed too? Well, you'll be pleased to hear that the Fuchs Motorsport range includes several Titan Race gear and diff oils too! You will find them HERE.
If you need any filters for your vehicle, follow THIS LINK and enter your vehicle details to find the OEM quality filter for your specific vehicle. We also offer specialist filters from K&N, HAMP, Honda Genuine, Mitsubishi Genuine, Nissan Genuine and Subaru Genuine.
If you need a bit of advice on choosing the perfect oil for your particular vehicle, give us a call on 01209 202 944 Monday to Friday, 8:30-5:30 or drop us an email to [email protected] and we can provide a free bespoke recommendation for you.
FYI - We would highly recommend getting your orders in ASAP as we will be getting very busy over the next few weeks - avoid the Easter rush!
If you require more information on the benefits of using fully synthetic oils such as these, feel free to have a look through one of our technical documents, simply follow THIS LINK.
That's all for now folks!
- Oilman
