My New Car.
scoopeydiesel
Re: My New Car.
Post by scoopeydiesel »
I was having a look at some of the topics on this site about tow bar electrics and as you have said and previously posted I can go straight into the electrics. I will only be towing a trailer no caravan. On some cars you can hear a buzzer when you turn on the indicators, what will I need for that. I don’t want to sound stupid but when you say solder, do you mean strip back a little wire and make a solder connection rather than cutting.
Re: My New Car.
Yes strip back the wires and solder them back along with
The new wire your adding.
(Heat shrink ) is just a sleeve you put over ...heat it and it shrinks .thus keeping the wires
Properly insulated..and protects them .
I've just had a brand-new tow bar removed from my Mondeo..
Its got all the buzzers and other gadgets..
Your welcome to them if you want them.
benczuk
Re: My New Car.
Post by benczuk »
lozz wrote:If your towing a caravan and you want to run the fridge
Or charge the caravan battery..no
I know you said trailer, but for accuracy there is actually a power feed behind the drivers side rear light for the above purpose (look for the thicker red cable that goes nowhere, this was on both my estates, not had a saloon)
Re: My New Car.
That wouid be a ' permant live feed wouidnt it.
What I meant was ...if you was intending on...towing a caravan which has fridge / battery
Then u couidnt just wire straight in to cars wiring.
Split charge relays etc wouid be needed?
benczuk
Re: My New Car.
Post by benczuk »
or a normal switch you turn on when towing :supafrisk:
dirtydirtydiesel
Re: My New Car.
Post by dirtydirtydiesel »
If you buy a new complete kit it should be all included, just check with the seller first
The buzzer you ask about is part of the kit & is wired into the indicators.
I would expect a kit to include a wiring diagram, it's pretty straightforward & you'll only need single elec's
for towing a trailer, oh & yes you wire it all in off the rear lights.
Hope this is of some help :)
scoopeydiesel
Re: My New Car.
It looks like i’ve got the speedo issue sorted; I replaced the sensor on the gearbox last night and its working perfect today. I took a sensor off a D8 - 1997 1.9 TD, it was very slightly different but it fitted and worked. Anyone know if the TD sensor is ok to use on the HDI as I have a funny feeling that it may be slightly down on power but not sure. The other issue is the temperamental temperature gauge which I suspect is the blue sensor on the engine but that's not too urgent at the moment. The driver’s side footwell carpet is still very damp from the fixed leaking sunroof. I am going to take out the carpet for a week and let it air dry. I have the NCT at 9:30 in the morning which is the equivalent of the MOT; it should pass as the MOT was done last Sept about 1000 miles ago.
scoopeydiesel
Re: My New Car.
lozz wrote:Yes strip back the wires and solder them back along with
Lozz. Thank you very much for such a kind offer, honestly I couldn’t take it as you can sell that for nice money on the web. I am going to order a Witter towbar with single electrics over the weekend. I will look for the buzzer later if it's not included in the wiring kit. Thanks again Lozz.
scoopeydiesel
Re: My New Car.
Failed the NCT see below, everything was fine except a Visual/Aural on the rear upper suspension link arms (the ones with the camber type washer). I know it's an easy fix but setting the camber is the most difficult as the new links may be a different length and marking the washer isn’t much good then. I was looking on ebay and there is some tool for setting the camber. Anyone used one or could recommend one. I found this on the subject and does anyone know how to follow it?. I have asked in a few tyre places and none do the four wheel adjustment.
“”There's a lot of fuss about this H2, which is the height of the rear jacking point above the ground. You're meant to use spring compressors but I remember in the old days it was putting weights into the car.
Description---------------------------saloon/ coupe------estate
H2 ( mm )-----------------------------160,0---------------180,0
Tracking by wheel ( mm ) ± 0,5-----1,5-----------------up to build code 09580 : 2,00 mm - From build code 09581 : 2,75 mm
Camber (°) ± 30'........................... - 1° 50'
Hope that looks ok.
I guess the rear suspension is sort of multi-linked, so the alignment changes as the spring is compressed & released. SO I guess that means anyone who lowers their car can expect rear tyre wear...”””
LucyAnderson2016
Re: My New Car.
Post by LucyAnderson2016 »
scoopeydiesel wrote:I was having a look at some of the topics on this site about tow bar electrics and as you have said and previously posted I can go straight into the electrics. I will only be towing a trailer no caravan. On some cars you can hear a buzzer when you turn on the indicators, what will I need for that. I don’t want to sound stupid but when you say solder, do you mean strip back a little wire and make a solder connection rather than cutting.
Glad to see there is thread about this as I was hoping for some advice on towing a trailer myself! The family and I are planning a holiday to Cornwall this summer and have decided to try taking a caravan as we love being out doors, and have two dogs which makes going away a little difficult as most hotels don't allow them. I have had a look online and think we will hire one of these trailers fromhttps://www.campanda.com/. We are not sure about buying one just yet, I guess if we do the trip again we go for it, but we'll just stick to rental for now. How did you find towing a trailer with th 406? My husband and I haven't done it before so any tips for things to watch out for would be great. Thanks very much.
benczuk
Re: My New Car.
Post by benczuk »
The 406 is a very good tow car. The 2.2HDi won tow car of the year in 2002, just make sure the weights of the car and caravan are a good match.
scoopeydiesel
Re: My New Car.
The 406 is grand for towing. I've been towing trailers with a 406 for about 15 years and no issues. Just one word of advice - don't go silly on the speed and take it steady.
Re: My New Car.
scoopeydiesel wrote:I've been towing trailers with a 406 for about 15 years
Wow, did you have a lot of stuff to move? :cheesy:
jasper5
Re: My New Car.
Post by jasper5 »
scoopeydiesel wrote:Failed the NCT see below, everything was fine except a Visual/Aural on the rear upper suspension link arms (the ones with the camber type washer). I know it's an easy fix but setting the camber is the most difficult as the new links may be a different length and marking the washer isn’t much good then. I was looking on ebay and there is some tool for setting the camber. Anyone used one or could recommend one. I found this on the subject and does anyone know how to follow it?. I have asked in a few tyre places and none do the four wheel adjustment.
Hope that looks ok.
When you adjust the eccentric washers you are adjusting the rear alignment (tracking) and not the camber.
