Are you leasing?Bailes1992 wrote: ↑Thu May 02, 2019 4:42 pm We just recently chopped the Wife's Duster in for an Sandero to reduce our monthly outgoings a bit.
This turbo shut down noise, I'll have to video it and show you all, confused now.....
Without going into too much detail...Welly wrote: ↑Fri May 03, 2019 8:27 amAre you leasing?Bailes1992 wrote: ↑Thu May 02, 2019 4:42 pm We just recently chopped the Wife's Duster in for an Sandero to reduce our monthly outgoings a bit.
Ah, yours is some Toyota 4 speed. I assumed you'd have a later 6 speed.steve_earwig wrote: ↑Fri May 03, 2019 9:29 am YoyoII's like that, I seem to get better economy of I thrash it than I do if I drive it like an old lady...
Re. the gearbox seems to be a U140F, not sure who makes it but it seems to be on Haiundies and Keers too. Not sure what you mean by idle, engine or gearbox? What it's done a couple of times is if I let off going up a hill and coast almost to a stop, when I press the throttle again there is no drive, the engine revs up and, before I can do anything about it, suddenly it's in gear again and we're off, BANG!
Also, it does seem to take a while to change into top gear when it's cold, the car doesn't interest me very much but I presume this is the lock up waiting for some heat as you say.
We know a song about in-house automatic gearboxes in this very thread 4 speed with underdrive apparently, I only know that because it's in the service history, being replaced at 42,685km. I dunno how it works but it seems to change gear rather a lot and I seem to get different gears if I select them manually. I don't think reverse goes through this underdrive as it's pretty fierce, especially when cold.
Have you replaced the transmission fluid in your slushbox yet?steve_earwig wrote: ↑Fri May 03, 2019 2:49 pmWe know a song about in-house automatic gearboxes in this very thread 4 speed with underdrive apparently, I only know that because it's in the service history, being replaced at 42,685km. I dunno how it works but it seems to change gear rather a lot and I seem to get different gears if I select them manually. I don't think reverse goes through this underdrive as it's pretty fierce, especially when cold.
Before this I've only owned cars with BW's that had no electrickery, just fluid pressure. They seemed to run fine to me, so I'm not sure whey they need computers now. I suppose how they run is only as good as the programming and if you do something that falls outside what they expect they will have a bad hair day.
I'm planning on 20k intervals, like yours I'll only be able to drain 3-4 litres out of ~10l capacity. I figure changing out 3-4 litres every 20k will still leave me with a much better maintained gearbox than 99% of automatics on the roads.steve_earwig wrote: ↑Wed May 08, 2019 8:11 am I can't find the specs now but the transmission takes something like 9 litres but if you drain it you only get about 3. When we got the car it looked a bit cloudy, maybe something to with the underdrive failure (it looked fine when we were buying it ) There's probably a way to pump out the whole lot while pumping new in but I thought it would probably be easier/less risky just to dilute the contaminants by changing those 3 litres every service. On the last service it was looking pretty clean so I'm thinking perhaps it's not so important now, maybe every other service would be ok.
It's probably complete overkill to change the oil, Toyota says it should never need changing (yeah, right), but as I'll be keeping this for quite a while it's worth it to me for peace of mind, if nothing else.
I don't believe for a second that any fluid is 'fit for life'. I feel that we got to a point in the 90's and even into the 00's somewhat where cars almost became too reliable. The B5 Passat is bullet proof, Peugeot 406 is bullet proof, Peugeot 306 is bullet proof, MK1 Focus is mechanically bullet proof, All Mondeos are renown for being utterly reliable and it goes on and on.trufflehunt wrote: ↑Wed May 08, 2019 10:00 am On my Golf TDI, there are no recommended intervals for changing gearbox oil. In fact,
there is no mention at all of changing it. Nothing in any of the VW servicing/maintenance/owners
handbooks that the previous owner passed on to me.
Last summer, at 225,000 miles, going from 2nd to 3rd, 3rd to 4th.., and back down, was becoming
a real problem.., baulking all over the place. On the forums, and fbook places..., it was all adjust this,
tighten that. I just kept looking at the mileage, and thinking that's a lot of miles.
So I changed the oil. Gear change now completely smooth.
Bloody hell, look at all the comments slagging each other off about what's right or not rightBailes1992 wrote: ↑Thu May 09, 2019 3:00 pm A thread I did on Bob Is The Oil Guy when I dropped the oil in our Sandero at 1000miles...
