Or you could just go to the esso station in penydarren and park it facing down hill, same effect, no funny looksdarrenwall wrote:i put £64 diesel in mine yesterday and that was 94.9p a litre ( 1p cheaper than unleaded) and the red light had been on for the past 45 miles so that took it up to 560 miles since i last brimmed it . i find the trick is to fill it right up is shake the car by grabbing the roof rails and when you do that a few times put the cap back on and you can hear the diesel being sucked down the neck for some reason and that way i can get an extrta £1 worth in there
. its no wonder i get funny looks filling my car up then
I remember brimming it @ 75 litres, petrol started to come out of the filler point when I removed the nozzle, so I just bunged the cap onmbell666 wrote:Think i've put nearly 75 litres in mine, not bad for a 70 litre tank! £70.50 @ 97.9p, never again!
The first time i filled it up, i was almost lying on the ground checking for fuel leaks, going where the hell is it all going!
I pretty quickly found the way to fill is to put the pump in upside down, works a treat.
Had 57.7 mpg out of mine the other night coming home from work (i too took a photo). strange as most of the time i get about 53, always between 49 and 55 mpg.
did once have it around the 60mpg mark, was a long trip from yorkshire to the south of london in the wet, spend the entire journey doing a constant 60mph due to traffic.
