Well done lad, what about some pics?
No probs fella, you know what you gotta doeoin27 wrote:Mr. Rees, I would like to place an order for a 406oc sticker.
Do you mean the bulb is nearly new or the headlight unit itself? If it's the bulb it's not seated correctly, take it out and put it back in. If it's the unit I think there's a motor for the adjusters that's connected by a ball joint type thing*, I'd bet that's not in right.eoin27 wrote:2)The off side headlight is nearly new and the leveler adjuster is pointing the light all the way to the bottom and thats as high as i can adjust it with the screwdriver. the n/s one is perfect.
What was it?eoin27 wrote:PS. Sorted the headlight issue!
The trouble is when the sun takes its toll and it fades to a lovely pinkdogslife wrote:I've always thought coupe's are meant to be that colour...
I know how to set the memory position but it doesnt stay in that position after i start the car, even after they finish moving around.Welly wrote:My mirrors sometimes did a 'silly dance' when you put the key in. Try making the adjustment with the engine running and then press-and-hold the M and 1 button until it beeps - see how it goes.
Im way too good a driver for a volvo. Perhaps when im older and losing my eyesight I'll get one!Welly wrote:Nice car BTW, but needs a new badge, here have this one ...............
