And the Focus does it again...
Bailes1992
Re: And the Focus does it again...
Post by Bailes1992 »
Well it's about to clock over to 90,000mile and it's had start/stop driving all it's life up until I got it off my Mum.
In it's life...
New clutch ~70k Considering the hard driving it's done, I'd say thats pretty reasonable
3 coil packs Ford items are weak, cheap pattern parts even more so. Now have an MSD coilpack
Front suspension has had to be overhauled Again, my Mum's hard on her cars and I'd say it's about right. Focus steering racks are known to be weak anyway
Rear bearings were replaced because the rear drums were worn, just a precautionary measure. The fact they've failed now is the mechanics fault.
Immob I think is a damp issue myself including the fried ECU.
It's hard a pretty hard life and my Mum dosen't notice niggly issues which is why they've gotten a little serious. So really I'm just catching up on 8 years of hard wear and tear.
Getting there slowly though :D
Bailes1992
Mechanic took my car today, checked the bearing for wear, cleaned it out, regreased. Then pressed it back in and replaced the hub nut and retorqued it.
Hopefully thats it now :) Apparently it had just worked it's way loose.
Glad its not my car,
sorry no offence but removing a wheel bearing and packing it with grease is bad practice,
you wouid of been better off Replacing it for what they cost,
once theyre removed and refitted theyre as good as goosed imho
Bailes1992
If it starts showing signs of going then I'l get him to replace it. For now it can stay as it is.
Bailes1992
Thats one shiny ass engine bay :evil: :evil: :evil: :evil: :evil:
Missing oil filler cap?
Bloomin ek dude,
you have no luck with this car :(
How did you manage to loose oil cap?
Ican spy a focus sitting unlocked in my yard, need any parts :P
What's that wire coming out between the plugs and heading off to the left? Looks like a dog's been chewing it :shock:
steve_earwig wrote:What's that wire coming out between the plugs and heading off to the left? Looks like a dog's been chewing it :shock:
iirc that be the cam sensor,
yup iagree mate, looks abit Chewed that but ithink thats how they are,
ford are abit cheap skate- with protective coverings of wires/cables
Bailes1992
Thats the cable for the head tempreture sensor.
And yeah the oil filler cap must of come off on my way to work this morning. AA man come out with a spare and a litre of oil, £16 in parts :cry:
Ahh well :(
£16 is not to bad is it?
couida been worse
so did you forget to put the cap on or as it blown its self off?
Bailes1992
Don't think it's 'blown' itself off, theres no damage to the fitting.
I topped the oil up 2 weeks ago, maybe I didn't turn it far enough? It's a bayonett fitting sort of thing.
They can fall off if you don't hear them click/screw them down right, my mum decided to top up the oil and check the coolant on the clio after i pointed out where they were located, a few days later i had to go to the scrapyard to get both of them caps :cheesy:
It shouldn't blow itself off, is the breather pipe at the top clear of sludge?
Bailes1992
Bought a litre of Gunk engine degreaser tonight and leant my grans steam cleaner.
Everywhere in my engine is covered in old, the reccessed in the bonet most have 500ml of oil in them? The bulkhead, sparkplug holes, EVERYWHERE!
Started to burn off on my way to/from work making me abit woozy and have a cracker of a headache :(
