Worried
- jameslxdt
ill just compare it to the gti6 one, that should tell me if it would fit or not, just with that extra camshaft on the head its unlikely the turbo will fit on it
Excellent guys really helpful. To answer your question yes I do have a boost gauge and dont know how to use it lol and a had a street race with a Hyundai Coupe 2.0SE and won really impressed with my car. But guys how come my Dump Valve dont sound loud? dont get me wrong i can hear it but not that load its a Bailey?
- niz406
- Admin <BR>Turbo God
My mate turned the nut on the akchewator rod so it pressed harder on the waste gate and he sez its a lot quicker now and didn't cost anythink.
i dont no if this works but he said it did .lol.
- niz406
Welton, your on the money...
Putting more pressure on the Actuator spring will produce more boost as it delays the opening of the wastegate by raising the reaction pressure and helps to prevent wastegate creep.
You can make it louder, by:
1 - Increasing boost
2 - Cutting / removing under bonnett insulation
3 - Winding your window down
4 - Resolving any boost or vacume leaks
Do you know what BAR your using?
- niz406
- niz406
did some one fit you a baily dump valve or did you fit it?
The baily one makes the Turbo boost pressure high when you change the gears, my mate has a scooby and he fitted a dump valve HKS one. and after he got flames from the exhaust because he said the boost was higher and that made the eggsauce manifold hotter to ignight the flames from the petrol cos Jap engines dump fuel aswell when you lift off.
i think niz means cut some off the blanket thing under the bonnet then the dump valve noise will echo more around and sound cool. i might just take the whole thing of should sound louder for you.
Omg u guys been increditably helpful thank you guys. lol it was so funny of me not getting were u ment lol. Guest were i checked? Under the car lmao hehehe anywyas cheers guys. And if its possible can i ask another question. Well firstly i have a cork attched to a hole near my Dump Valave is that were the BOV should go or were should it go? Thank You
- niz406
Result
Right this is what a did took the carpet off which was under the bonnet and then bloked the pipe which the BOV was conected and GUYS WOW IT SOUNDS AMAZING REALLY THANK YOU ITS FANTASTIC. ILL GET PICS UP TODAY OR TOMORROW.
