Well that's annoying!
Bailes1992
Re: Well that's annoying!
Post by Bailes1992 »
Also Rich bare in mind the manafacturers rate their tyres.
Personally I think an independent body should test them.
Bailes1992 wrote: I was only getting Budgets to prove to the other half that they are an utter waste of money!
You're wasting money to prove that it's a waste of money? That's mad Ted :shock:
I'll cut my arm off to prove that cutting my arm off hurts...
There are independent testers, http://www.tyrereviews.co.uk/Article/To ... -Guide.htm http://www.tyretest.com/ but they're not all that helpful as there just aren't enough reviews. Also some tyres suit some cars but are rubbish on others. And I suspect there's a fair amount of reviews on there that aren't legit.
Bailes1992
Just been out for a good drive. Road were damp/greasy.
They are definitely harder than the ContiSportContact3s I had previously.
They offered more grip in the wet than I ever got from the Contis.
There is a bit more feeling in the steering too.
I'm quite impressed. Il get the tyre pressures adjusted in the morning when they are cold and see how they manage in the dry.
and they're not even scrubbed in yet :shock:
rwb
Post by rwb »
Disappointingly acceptable? :P
Bailes1992
I wouldn't say that Rich. Hankooks aren't budgets! They are a good mid range tyre like a Khumo or a Falken.
Just happy they seem to be up there with the Continentials/Bridgestones/Goodyears etc that I use usually!
rwb
Post by rwb »
Well if we believe the ratings then they certainly ought to be.
Four Sunnys (C/C/71) on the '7 and I haven't found the limit... yet.
gumby6371
Post by gumby6371 »
Is it just me or isn't it a daft idea to push through the twisty bits on wet greasy roads regardless of the name on the side of the rubber?
I fully agree you should buy the best quality you can afford but as with so many things buying the expensive/well known brand name of anything doesn't always mean you're buying the best.
Just running it up the flagpole and seeing who salutes
I've tried Kumhoes and yes they were very good.........but didn't last long. We run Mercedes Vito's at work and have found that the Continental tyres would get at least 40K miles but the budget/mid-rangers would see about 25K so the Premium brands do kinda work financially although a bit eye-watering to begin.
OllieNZ
Post by OllieNZ »
gumby6371 wrote:Is it just me or isn't it a daft idea to push through the twisty bits on wet greasy roads regardless of the name on the side of the rubber?
I'll salute that.
If you're driving like a tool in the wet you deserve to fall off the road regardless of rubber. Just like 4wds in the snow. Even though my pajero had a brand new set of bfg mt tyres on it you still needed to take care cos the lsd had a habit of locking around corners and kicking the back end out:x .
I've recently had nankang ns2 fitted to my car and no complaints so far, better than the mix of michelins that came off it. I bought them after talking to a friend who has 19"s on his A6 and his only complaint was they were tad noiser than the contis they replaced but after 16,000miles he hadnt noticed any other difference
Bailes1992
Time and a place an' all that.
Nothing wrong with progressively testing your car on quiet roads regardless of the weather. As long as it's somewhere that if an accident were to happen you will only hurt yourself then what's the issue?
Don't for a second think I was launching my car into wet corners at a billion miles an hour because that's far from the truth. Take a slow, long bend and progressively apply the throttle until you feel a little under steer, there's your limit!
Also having good tyres isn't about being able to chuck your car about in the wet! It's about knowing that if for any reason I had to take evasive action, if for any reason I have to slam my brakes on or if for any reason I need to drop a gear and accelerate out of a situation I, within reason have the most grip possible to help my remove myself from that hazardous situation.
