Refreshing Power Steering fluid
Re: Refreshing Power Steering fluid
Welly wrote: Tue Jun 09, 2020 10:57 am Volvo Publication:
EHPAS (Electro Hydraulic Power Assisted Steering)
The system has a hydraulic pump driven by an electric motor. The electric motor is controlled by the
control module. The control module adapts the servo power based on the speed of the car and how fast
the steering wheel is being turned.
Blah blah blah mind glazes over
80 AMPS!! :shock:
8x12=96... That's almost a sodding kilowatt :shock: :shock:
I've no idea what sort the yoyo has, I know it's electric (bah du ba bah) but I thought it was connected to a hydrollick pump like the first one in the picture. Hold on a mo... now I bother to look there's a motor on the steering column (that's not available separately I note). I thought it felt ok but now of course it won't... :roll:
steve_earwig wrote: Tue Jun 09, 2020 6:01 pm I thought it felt ok but now of course it won't... :roll:
Don't see any fundamental reason why it can't behave as well as any other system.
All it needs is a talented software/drives application engineer that can actually drive a car instead of a playstation
The last couple of new Hire Cars I've driven have had horrid steering, very light with no 'feel' but that seems to be what we want/are given now :frown:
steve_earwig wrote: Fri May 29, 2020 7:00 pm
Autoweak wrote:if you want to understand how the road is changing and reacting to your tires, you’re out of luck...if automakers only built cars for enthusiasts they’d be out of business in a week. It’s a tradeoff...If you really want steering feel, get an old Lotus Exige or an Alfa 4C
It's almost as though "they"'re trying to remove all elements of enjoyment from motoring. Which I guess is the point :(
