i cant do anything like that just yet as need rear tyres! replaced front so just the over steering to sort now! fun it is
need a service and cambelt aswell
ah right, the stop solenoid, are you not able to cut through the shield with an angle grinder to gain access to the max fuel screw? never seen a 406's pump yet.jameslxdt wrote:
all 406 1.9 have a bosch pump, but the max fueling screw is coverd by the immobiliser stop solenoid shield, and you have to take the pump off and dril out this cover, also the to adjust the on boost fueling you have to dismantle the pump
Now why does this all sound like a recipe for blowing ones engine and/or its components to pieces with over pressure or some such?philg wrote:ah right, the stop solenoid, are you not able to cut through the shield with an angle grinder to gain access to the max fuel screw? never seen a 406's pump yet.jameslxdt wrote:
To adjust the on boost fueling you only have to remove the 4 bolts on top of the 'turrent', mark the valves position, and take out the nylon washer to allow more valve movement, then reassemble.
Thats what i was saying, i havn't seen a 406's pump, i'm only familier with the 306's pump. What does the ecu control on them?turbolag wrote:Don't try altering the pump settings on the 406 XUD as you would on a 306 XUD, as the 406 uses a nasty lash up that controls certain parameters of the fuelling electronically - if you try to alter th max fuelling, and off boost fuelling, the car will try and compensate for this and it'll end up a mess. Derv Doctor can do optimisation on hese motors, and it's worth spending he money to have them get it right first time, rather than spend weeks stopping every 400 yards to nip the screw round another 8th turn!
Ade, you taking the 406 to Pugfest, or d'ya reckon you'll have project Millenium Falcon sorted by then?
i tried everything on my old one, and that shield is one bloody strong bugger, you have to remove the pump and drill out the shear bolts, theres no easy way about itphilg wrote:ah right, the stop solenoid, are you not able to cut through the shield with an angle grinder to gain access to the max fuel screw? never seen a 406's pump yet.jameslxdt wrote:
from another post:turbolag wrote:Dunno bud. The official line is 'certain fueling parameters', but i've never had a play with one. Mebbe James might know?philg wrote:Thats what i was saying, i havn't seen a 406's pump, i'm only familier with the 306's pump. What does the ecu control on them?
dervpower wrote:
which motors did you say were semi electronic and how does that work?
basically it does sod all, and turning up the max fuel screw wont mess up the engine management in anway really, if your worried about it doing anything fit a 306 bosch pump, as they are identical apart from the on boost fuel controller, and the hydraulic advance regulator solenoid in the 406 bosch pumpjameslxdt wrote:all 1.9's in the 406 had semi electronic injection and just controls preheating, postheating and the injection angle/timing, injection duration, on boost fueling and total fuel quantity is still controlled by the pump
it works by using a needle lift sensor, throttle position sensor and rpm sensor to determine the angle/timing and a coolant sensor to control the glowplugs
the only reason they fit the anti-tamper shield and shear bolts to hold it in place is because of the immobiliser as if you could get to the stop solenoid, which the sheild covers, you could easily steal itBlue406 wrote:Now why does this all sound like a recipe for blowing ones engine and/or its components to pieces with over pressure or some such?philg wrote:ah right, the stop solenoid, are you not able to cut through the shield with an angle grinder to gain access to the max fuel screw? never seen a 406's pump yet.jameslxdt wrote:
Seems to me that if you have to angle grind, cut or drill a casing... then the screw ISN'T meant to be tampered with?!
