Those 'simple' DIY jobs..
Re: Those 'simple' DIY jobs..
I noted, with interest, upon my holiday to spain, that the quality of the tiling there was superb
. I was sat creaming out a cumberland one morning and marveled at the supreme quality of it all where the floor tiling seamlessly blended with the wall tiling and pondered whether I would be able to achieve anything similar. I called for Mrs Welly to come in and inspect the standard of fit and finish from a Womans' view point but she declined.
Clutch is fine - no slipping - but although the judder I initially reported has died down a lot it's still got a nasty shake when holding the car on the clutch. I suspect I should have shelled out for a new lower mount. At least I've got an upcoming opportunity to do it - o/s CV boot is split and the MOT's due next monthteamster1975 wrote:I've meant to ask you, how's the car going now you've been running it for a few weeks?
Also seems I've done something bad as it's leaking fluid. Either through the sump gasket (I did have the engine supported by the sump for about a week
Actually now you've reminded me, the stealers still owe me some bits they had to back-order, including a new lower air intake hose (under the wheelarch jobbie)
Apart from that it's all quite good. Think I've figured out what's wrong with my stereo too - the 4xRCA to ISO connector I'm using passes all 8 wires from the RCA connector down to the loom, whereas the JBL takes 4 channels and just one ground... I'm going to see if joining the -ve lines with a couple of bent paperclips does the job so I can re-wire it
Oh yeah, I need to fork out £87 for a new set of front brakepads before the MOT too, clean up the callipers and get a new pair of rear tyres thanks to the excessive camber when I bought it.
The car's just about in my good books though, especially after its flawless (apart from the really really annoying backplate droning) performance going to Hamburg and back
Tiling should be easy if you've got a nice, flat surface to tile on. Let me know when you find oneWelly wrote:On the subject of tiling, a friend told me that the tiling was fairly easy but it is the grouting that is an arse....thinking he was mad I commenced tiling my bathroom and then agreed with said grouting being an arse, even with my ubber grout applicator and grout sponge.
I've got a really cheap one (sans table) but with a decent diamond blade. SOme of the tiles I've used are really hard and quite expensive, the scoring machine just isn't accurate enough. My last bit of tiling was the room all my cat stuff is in, it's the one the water got into the parquet in so it had to go. I used the cheapest floor tiles I could get my hands on (about 3 quid a meter) and, while I was tiling I found out why they're so cheap - I did a 15 cm sokol (think skirting) around the edge after I did the floor so it wouldn't damage the walls when I was washing the floor. While I was doing this I had 4 tiles crack on corners where I'd missed with the glue, won't be doing that again.He also saw my diamond bladed water-bath table top tile cutter machine and burst out laughing saying it was a waste of time and money and I should use the traditional 'score back and forth' type thing and nibblers ....![]()
That shower room, those expensive, hard, Italian tiles... with something like 16 holes I had to makeDefinately a task *well* worth pre-planning and working out the cuts etc. beforehand for a neat and uniform job.
Where from?? All the breakers over there I "spoke" to wanted to sell me the complete suspension arm (imagine the postage...)mjb wrote: Then I've got to get a new pair of rear backplates (£30 used)
They really are cheap aren't they (on the floor) - they even de-coloured from beige to blue
All this talk and pictures of you guy's DIY's is (beginning) to revive my interest in tiling the bathroom floor(s) here, I say 'beginning'.....
I'll probably start on this place about 3 months before selling it to 'freshen it up'
Different lighting I guess.
Always helps. And the next owners will rip it all out (usually happens with kitchens). My dad still visits the lady he used to live next door to in Sussex, he keeps bemoaning how the new owner is ripping everything out that he did, I keep telling him the way it was helped sell it and it's up to the new owner what he does with it, even if it involves driving a bulldozer through itWelly wrote:I'll probably start on this place about 3 months before selling it to 'freshen it up'
- Captain Jack
So, where's the howto?mjb wrote:<clutch stuff>teamster1975 wrote:I've meant to ask you, how's the car going now you've been running it for a few weeks?
UrghCaptain Jack wrote:So, where's the howto?
