Steering Vibrations?
Re: Steering Vibrations?
You won't get the theramin in the boot either :supafrisk:
Bailes1992 wrote:they've sent me one unbranded one and one Qdrive wishbone.
What does the invoice say? If they cocked-up it's their job to put it right.
Bailes1992
Post by Bailes1992 »
steve_earwig wrote:You won't get the theramin in the boot either :supafrisk:
Basically Euro Car Parts have like unbranded stuff on there website, I ordered two of those and a Q-Drive one and an unbranded one turned up. Well I can give them a ring and see what they say.
This is my order...
Code: Select all
Order Lines:
1 x 606590560 @ 10.11 GBP
 Track Rod End (Left  Hand)   Ford Focus  1.6 2002 (CA52JLX)
1 x 606590570 @ 10.11 GBP
 Track Rod End (Right Hand)   Ford Focus  1.6 2002 (CA52JLX)
2 x 632590140 @ 6.82 GBP
 Stabiliser Link / Drop Link (Left  Hand Right Hand)   Ford Focus  1.6 2002 (CA52JLX)
1 x 615590380 @ 44.06 GBP
 Suspension Arm (Left  Hand)   Ford Focus  1.6 2002 (CA52JLX)
1 x 615590390 @ 44.06 GBP
 Suspension Arm (Right Hand)   Ford Focus  1.6 2002 (CA52JLX)
Is europarts a big store franchise?, my front 2 droplinks came from europarts dungannon, and they wernt genuine pug, come to think of it nor was the exhaust which also came from the same place. Much cheaper than ebay or peugeot for the same parts and they do the job well.
Bailes1992
406executiveHDI wrote:Is europarts a big store franchise?, my front 2 droplinks came from europarts dungannon, and they wernt genuine pug, come to think of it nor was the exhaust which also came from the same place. Much cheaper than ebay or peugeot for the same parts and they do the job well.
I'm just afraid the car will handle abit funny :(
Mine handled better after the droplinks were replaced.
Bailes1992
My droplinks are fine tbh. And Euro car parts are just liek another motorfactors, there web service is based in Wembley.
Bailes1992
http://www.ehow.com/how_6292668_check-bad-tie-rods.html
Defo think this is all down to a track rod now :)
Was going to sit down and just do the track rods today, but knowing my luck I'd break something, not exactly somethign I want to do while the car is on the top of my drive :(
jasper5
Post by jasper5 »
That link is referring to track rods...you have bought track rod ends.
The track rod in the link is the inner joint on the steering rack and the rod that it attaches to.
The track rod end is the bit that screws on the end of the track rod and fits to the hub at the wheel.
Bailes1992
jasper5 wrote:That link is referring to track rods...you have bought track rod ends.
Americans refer to track rod ends as tie rods :)
All my symptoms match, clucking over bumps, clucking from lock to lock and vibrations :)
Alsoo...
jasper5
Post by jasper5 »
The link still refers to the inner tie rod (track rod), you have bought tie rod ends (track rod ends).
The safety check refers to SLIGHT play in a track rod END which is what you have bought.
The link indicates a fault with the tie rods (track rods) inner joints, there is no mention of those on the safety check.
Your fault may well relate to the inner track rod joints (tie rods), but you are changing the outer track rod ends (tie rod ends).
I would have expected the safety check to have refered to a fault with the inner joints though.
Bailes1992
jasper5 wrote:The link still refers to the inner tie rod (track rod), you have bought tie rod ends (track rod ends).
I still think it's the track rod end.
jasper5
Post by jasper5 »
At least if you change it you can eliminate it.
It's a very simple job after all.
I hope you are right.
Bailes1992
jasper5 wrote:At least if you change it you can eliminate it.
Well tommorow I'l get the wheels swapped round and see if it fixed it. (meant to do this today but fitted my subwoofer instead. Prioirtys and everything :lol: ).
CHeck for play in the inner joint while you're there...
Bailes1992
steve_earwig wrote:CHeck for play in the inner joint while you're there...
How'd you do that?
