Welly wrote:Something else to remember is that you'll end up with your new floor down before you've finished with the painting so need to take care protecting it all.
How do you painter guys get on with this? you bang the floor down and then fit the skirting, pre-painting the skirting doesn't give the best finish imo because you've still got the cutting-in against the wall/joints to do and using caulking looks messy to me.
I always neatly caulk the skirtings/architraves, emulsion down to the line, and then use the final glossing to give the finished cut-in to the wall and over the caulking.
ive redone all my house myself as well. painting , decorating. floors. doors , skurting boards. do it all myself. not paying no1 to do that a monkey can do it all
the way i did all rooms was rip the lot out 1st job (obviously)
lay the new floor is the 1st job
then fix new skirting boards and arkitraves. then caulk them all round.
good masking tape around the floor to paint skurting boards
wallpaper or painting fresh plastered walls is the last job because its the least messy job.
its all easy work its just time consuming that annoys me
