1.9 or 2ltr hdi
Re: 1.9 or 2ltr hdi
The mechanic here writes it in gold permanent marker on the cam belt cover - can't bluddy miss it! I didn't know it was a fairly common procedure because I've never had someone else work on my car before.
Re: 1.9 or 2ltr hdi
I did a mot history check on # 1 (the 117k one with no s/history) and all came back ok mileage wise, it had a recent fail/advisorie on the back rear tie rods and b/joints and back box.
Then again, after a test run yesterday I heard a bearing that needs done, so if (and it's only if) I go for it, I'll tell him as he said it'll come with an mot, so that'll need done
Re: 1.9 or 2ltr hdi
Tie rods aren't so expensive but you need to put them back in the same because they control rear wheel alignment (it's done with eccentric washers, you just mark where they were with a chisel). Is that front ball joints? I think the hub needs to come off and you need a special tool (someone?). Back box - 40 quid?
Re: 1.9 or 2ltr hdi
Ok...this is a copy of some of it....I didnt know they had b/joints in the back unless the tester got mixed up
Advisory Notice issued
Rear Brake pad(s) wearing thin (3.5.1f)
Rear both Brake disc(s) slightly pitted (3.5.1h)
Rear both Tie bar/rod has slight play in a ball joint (2.4.G.3)
Service brake Your vehicle has only just met the required service brake efficiency. It would appear that the braking system requires adjustment or repair. (3.7.A.9)
N/s handbrake cable worn
This bit is from this time last year...
Test expiry date:20/09/2011
Offside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.3)
Offside Track rod end ball joint has slight play (2.2.B.1f)
Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
Re: 1.9 or 2ltr hdi
There are lots of ball joints, it turns out it's not even the one I was worrying about.Stu63 wrote:Ok...this is a copy of some of it....I didnt know they had b/joints in the back unless the tester got mixed up
New disks and pads then, unless the disks aren't so bad. See viewtopic.php?f=10&t=7219Rear Brake pad(s) wearing thin (3.5.1f)
As above with the eccentric washer.Rear both Tie bar/rod has slight play in a ball joint (2.4.G.3)
The 406 is good at crap handbrakes, it what they often get advisories onService brake Your vehicle has only just met the required service brake efficiency. It would appear that the braking system requires adjustment or repair. (3.7.A.9)
I can't remember which way around it is but one cable goes all the way from the handbrake to one wheel, the other just ties onto it at the back (see the cable adjustment thread). I'm guessing worn is where it's been rubbing on suspension components.N/s handbrake cable worn
So this stuff might have been done?This bit is from this time last year...
Almost a service item on 406s, can be a pig if they've been there a while (out with the angle grinder)Offside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.3)
Not as bad as a bottom ball joint! Should be fairly easy to change but you'll probably need a ball joint splitter and possibly the steering geometry checked (probably not a bad idea to have it done anyway, given the age)Offside Track rod end ball joint has slight play (2.2.B.1f)
Part of the system? That's helpfulRear Exhaust has part of the system slightly deteriorated (7.1.1a)
Re: 1.9 or 2ltr hdi
I'm still not sure what to do, I emailed the 2nd one (the high mile'er) and said no thanks, as by the time he mot'd it and got a clutch in he wanted dam near £900, that's what the dealer wants for the first one (ie the one that these fails/advisories are for) with half the miles, ok there's no "history" but a bit better of a car.
Or I do bugger all and wait for something else
Re: 1.9 or 2ltr hdi
It's up to you, there's quite a few about. Although I'm not seeing anything surprising on those advisories, just the sort of stuff you'd expect on a car that age.
Re: 1.9 or 2ltr hdi
Yea I know, the high miler's sold....but I went to see a Citroen C5 2.0 hdi,nice....the oly thing putting me off is the expensive looking/sounding suspension system, gets a good a write upthough
Re: 1.9 or 2ltr hdi
I thought that was the best bit about owning a Citroen
I'm a bit out of date now so I don't know how much things have change but on my BXs the suspension spheres (5, possibly 6 now) can need changing (hard suspension on one corner means that sphere needs changing or if the pump keeps clicking the accumulator sphere's had it). They can be recharged if you get to them early enough but usually by the time you notice it's too late. A quick check says they cost 50 to 60 quid each. On older cars corrosion on the hydraulic lines could put the car beyond economical repair but I haven't seen much mention of that lately so perhaps they changed materials
http://www.citroenet.org.uk/miscellaneo ... ics-1.html
Paging Mr. Waue!
Paging Mr. Waue!
Re: 1.9 or 2ltr hdi
Thanks for the link Steve, I too am kind of out of touch technology, especially stuff like this and on French stuff (we all know the rep the French have for dodgy/crap electrics), I know I said they seem to get a good write but I forgot to say that the one I went to see is an auto....and seemingly the auto box is one of the worse on car yet. I've had a few autos and dont mind them at all, but on this model they seemingly "clunk" when changing whether up or down, but more so down, I felt something yesterday but not sure.
I liked it, but there was also something about I didnt like.....I guess I'll leave it too
Re: 1.9 or 2ltr hdi
I love autos but I hate paying for it when they go wrong...
Keep trawling the ads, the right car will come
- sirwiggum
Re: 1.9 or 2ltr hdi
Dunno how different they are, but spheres for the Xantia were £20 a corner, and renewing was as easy as oil filter renewal.
Re: 1.9 or 2ltr hdi
They might be cheaper, those were the first prices I found
- sirwiggum
Re: 1.9 or 2ltr hdi
Wouldn't let a Citroen's suspension put you off.
I'd rather be renewing spheres than renewing springs.
The hydraulic pipework etc. is exceptionally strong these days, and it no longer drives the brakes if this was a concern.
What a shame though that they're dropping it on the new base model C5s and the DS5 (which has ridiculously German stiff suspension!).
Re: 1.9 or 2ltr hdi
The Xantia and 406 share the same platform. I've always been tempted by a Xantia, possibly the next car. The problem with them though is that I hear a lot of the parts are becoming harder or more expensive to get. Certainly I've noticed a lot less Xantias on the road over the last couple of years
