mechanic told me that if it was some other car my wheels would go like DeLorean in Back to the future 2...
I live in the Belluno province, Italy. It's in the middle of the Dolomitis, near Cortina. We have loads of snow every year. Moreover, I enjoy hiking and climbing, so I have to drive up steep slopes and small snowy roads tens of times every year. I know how to drive on the snow pretty well. I've found myself stuck several times (especially with my mum's Clio with crappy winter tyres!), and I know hot to act in this case. I tried several times everything possible.lozz wrote:Myth?
try it,
get your car in some snow, try setting off in 1st
and then try setting off in 2nd, and see the differnce,
set off in 1st the car will just spin,
obviously you will have better grip with the winter tyres so you may not see much improvement,
but on ordinary tyres it does make a differnce..
Theres no Myth in it what so ever,
plenty of info on the net,
from one source,![]()
Driving in snow and ice
Gentle manoeuvres are the key to safe driving - stopping distances are 10 times longer in ice and snow.
Wear comfortable, dry shoes for driving. Cumbersome, snow-covered boots will slip on the pedals.
Pull away in second gear, easing your foot off the clutch gently to avoid wheel-spin.
Up hill - avoid having to stop part way up by waiting until it is clear of other cars or by leaving plenty of room to the car in front. Keep a constant speed, choosing the most suitable gear well in advance to avoid having to change down on the hill.
Down hill - reduce your speed before the hill, use a low gear and try to avoid using the brakes. Leave as much room as possible between you and the car in front.
If you have to use brakes then apply them gently. Release the brakes and de-clutch if the car skids.
Automatic transmission - under normal driving conditions (motorways, etc) it's best to select 'Drive' and let the gearbox do the work throughout the full gear range. In slippery, snowy conditions it's best to select '2', which limits the gear changes and also makes you less reliant on the brakes. Some autos have a 'Winter' mode which locks out first gear to reduce the risk of wheel spin. Check the handbook.
But in 2nd you have MORE wheelspin than in 1st. Let's say you let the car at idle and ease the clutch gently: in 1st at 800 rpms you are at ~5mph, in 2nd you are at ~9mph (approximate figures, you get the point).Pull away in second gear, easing your foot off the clutch gently to avoid wheel-spin.
The torque at the wheels is a increased in lower gears by the gear box - think in torque and not in terms of speed and it will become clear to you.OdinEidolon wrote:But in 2nd you have MORE wheelspin than in 1st. Let's say you let the car at idle and ease the clutch gently: in 1st at 800 rpms you are at ~5mph, in 2nd you are at ~9mph (approximate figures, you get the point).
So, more wheelspin. Makes no sense otherwise. The only diference is that by setting off in 1st you have more initial grip, but then you have to change gear earlier. And changing gear means interrupting the power to the wheels and risking to lose traction, but it's easy to correct, no big deal.
Why starting in 2nd? Why not in 3rd then! Or 4th! If 2nd is better then 1st, then 3rd is better than 2nd.
It's just a myth you have in UK, don't know why...
EDIT: also the "avoid wheelspin" stuff is madness... especially on summer tyres. Just the other day I helped a guy who was stuck on a steep hill, he had summer tyres and could not move. A friend of mine and myself started pushing from behind, he did not rev and the car was just stationary... we told him to rev it to 2000-2500 and keep it there, and off he went, no problems at all.
You have no grip - torque is not that important. Yes the torque to the wheel is lower in 2nd (and then in 3rd, 4th etc...), but a sudden increase corresponding to 800 rpms (from stationary to moving at idle) in 1st means getting from 0 to 5mph, in 2nd from 0 to 8-9mph. And when the wheels are "doing" 9mph the car is probably still doing 4-5mph... wheelspin!V6Exec wrote:The torque at the wheels is a increased in lower gears by the gear box - think in torque and not in terms of speed and it will become clear to you.OdinEidolon wrote:But in 2nd you have MORE wheelspin than in 1st. Let's say you let the car at idle and ease the clutch gently: in 1st at 800 rpms you are at ~5mph, in 2nd you are at ~9mph (approximate figures, you get the point).
In my old V6 I would show friends the "one gear trick". On a flat road at a standstill I would put the car in 5th, and slip the clutch a bit on tickover to get moving, then take my foot off the clutch and put it hard down on the accelerator. As the revs increased and the available torque increased the rate of acceleration increased.
One year on a clear road I was climbing a hill in 5th doing a decent speed, there was drifting snow at the crest that I was not aware of. When I hit the snow the available torque from the V6 in 5th gear caused a wheelspin.
In snow starting in a higher gear means that the engine is running with less power - less torque at the wheels means the ratio of grip to torque is better. And if you want the real proof. On a moderate road put a car in first, revs the nuts off it and dump the clutch - wheel spin. Try is in second and you will generally not get that spin.
Why then don't you start in 3rd? If the car stalls if you try to set off in 4th or 5th depends hugely on the type of engine and on the mapping of the low revs injected quantity. If you release the clutch very carefully, even my 406 can start in 4th. On the 106 1.5D I could do that in 5th, on my dad's C3 1.1 it was not possible in 4th or 5th, but OK in 3rd.lozz wrote:Why starting in 2nd? Why not in 3rd then! Or 4th! If 2nd is better then 1st, then 3rd is better than 2nd.
Any car thats got a decent clutch plate, normaly stalls if you try setting off in 4th,
if it was Myth why wouid 1st gear lock out on top notch auto cars be even thought of,
if you think its aload of bull, fare enough
+1 on that. Every EU country has by now realized that winter tyres in winter are a must, exept UK to be honest.KozmoNaut wrote:And as for the "I'll just drive carefully" argument, it's bunk. When there's ice and snow on the road, there is no way you can drive carefully enough that you're able to stop if someone runs out it front of you, even if you go 10mph and cause a traffic jam. Summer tyres are absolutely useless on snow and ice, even on dry roads in cold weather winter tyres fare better. Only if by "driving carefully" you mean "I'll stay home if there's any snow at all" can your decision to forego winter tyres be OK in any way.
There is friction between the tyre and the snow, layers of snow, and the road. That friction gives you grip, but it is very limited.OdinEidolon wrote:You have no grip - torque is not that important. Yes the torque to the wheel is lower in 2nd (and then in 3rd, 4th etc...), but a sudden increase corresponding to 800 rpms (from stationary to moving at idle) in 1st means getting from 0 to 5mph, in 2nd from 0 to 8-9mph. And when the wheels are "doing" 9mph the car is probably still doing 4-5mph... wheelspin!
Not quite - acceleration (rate of change in velocity) is highest in the lower gears. The maximum speed will be lower, but the acceleration higher.OdinEidolon wrote:Yes- torque is more, but for the same torque you also get faster acceleration because for every engine rpm you have more wheel rpms.
The two things obviously compensate each other (otherwise energy would no be conserved).
Driving style comes into this - depends if you use the throttle to control the speed whilst also using the clutch. Having driven a collection of vehicles of different types and sizes, I use one or the other not both (except on a steep hill start)OdinEidolon wrote:Of course you can control the power with the clutch but:
- this wears the clutch a lot
- you can do that in 1st too! And you'll have more control over the throttle.
Tbh I don't think I need to have someone tell me what acceleration is... What you say is wrong. When you depress the clutch the wheels go all of a sudden from 0 to 5mph (1st) or to ~double that (2nd gear). Of course you can modulate this by depressing the clutch very slowly, but not too much.V6Exec wrote:Not quite - acceleration (rate of change in velocity) is highest in the lower gears. The maximum speed will be lower, but the acceleration higher.OdinEidolon wrote:Yes- torque is more, but for the same torque you also get faster acceleration because for every engine rpm you have more wheel rpms.
jonsowman wrote:Reducing torque is indeed the key.
