yeah i thought you would have been out making the most of this only dry day to get some of it doneDaiRees wrote:Jobs to do on my Zook:
Finish body lift...
Weld up big hole in the boot and wheel arch.
primer / seam sealer / underseal / paint welded bit.
Repair or replace rear bumper brackets.
Fit replacement bumper.
Modify front bumper brackets
Fit front bumper and grille
Modify bull bar brackets
fit bull bar
strip replacement rear diff
fit "locker" to diff
rebuild diff
remove rear wheels
drain diff oil
pull out rear half shafts
remove prop shaft
remove diff.
fit replacement diff
pop the shafts back in
fill diff oil
refit prop shaft
replace wheels
go and have some fun!!!!
So the real question is, why the fek am I sitting here????
