dogslife wrote:Just a guess this, but isn't it possible for an injector to fail 'open' i.e. let far too much fuel through flooding that cylinder?jasper5 wrote:If you think about it, it's unlikely to be injectors not working if you can smell petrol in the exhaust.
Don't know how you could cut the fuel supply off to it though....
Well, another test to find a faulty injector, is to take off the electrical connector that goes to each injector in turn, so, this is the way to shut off a stuck open injector.....never heard of a stuck open injector.
When I get a 206 with a misfire, I first take off the electrical connectors from each injector in turn, as above, if there is no change in engine note when any single injector is disabled, that indicates the faulty cylinder.Vise versa, any change in engine note with an injector disabled indicates a working cylinder.
I do this because the coil pack is a complete unit of four cylinders, therefore you can't tell which cylinder is faulty.On the 206, you swap the injectors about first, as I said usually this fixes the misfire, but if the misfire is still there, it's the coil pack....saves buying a new coil pack at £60 unless you have to.
