Project HaeThere! (Coupé restoration)
Re: Project HaeThere! (Coupé restoration)
Is it possible that some plonker just spilled a load of oil when filling it? :?
That's always possible, another vote for clearing it all out & seeing where it's coming from then :cheesy:
Thinking about it, this might be why the oil on my D9's gearbox never came back after I cleaned it off :?
The weather forecast looks bad for this weekend so I can't risk doing any work :(
On the upside, it's given me the extra time i need to grab some syringes off ebay, which should speed up draining the oil. They'll also come in handy next time I need to change brake fluid
It also gives me time to try to figure out how to get access to the amp and potentially remove it
I reckon it was someone being clumsy filling the oil as well, the filler is pretty close to that bank.
Welton wrote:Maybe you'll just find one or two plug wells are full of oil where the O-ring has perished on the rocker cover....it happens :|
Ahem :cheesy: :wink:
The problem is usually an O-ring seal around the plug aperture as this is below the oiling-level going on inside of the head/valve train.
You whip off the rocker cover (sounds great doesn't it?) note you also need to get the main rectangular shaped rocker gasket and then you get access to the spark plug gaskets - normally round or maybe square shaped on yours. The heat makes them perish over time and oil fills the wells.
Some "bodgers" leave rags down there and do a weekly rag-change (eww).
Welton wrote:You whip off the rocker cover (sounds great doesn't it?) note you also need to get the main rectangular shaped rocker gasket and then you get access to the spark plug gaskets - normally round or maybe square shaped on yours. The heat makes them perish over time and oil fills the wells.
According to servicebox, there's no gaskets or seals between the inlet splitter and the head gasket...
I was just kinda recalling what you would normally need, but as we know, nothing's ever 'normal' around here :o
Welton wrote:I was just kinda recalling what you would normally need, but as we know, nothing's ever 'normal' around here :o
I dunno, it's normal for the handbrake to be useless, D8 blower fans to burn, saloons to turn their spare wheel well into a swimming pool, ashtray bulbs to blow regularly...
(ooh that last one reminds me of something i need to add to project haethere :) )
EDIT: d'oh! it's already there
eoin27
The Irish 406 addict
Post by eoin27 »
mjb wrote:ashtray bulbs to blow regularly
and the cigarette lighter bulb, its such a horrible job to change it too. You have to take the whole console off right?
Nah just the ashtray section and/or the gearstick gaiter. It's been a while since I've done it. Very easy job though
mmm.. my fag lighter illumination is bust too :roll:
10. Back seats. Won't lock in the upright position :shock:
Just need slamming. VERY HARD :shock:
19. Rear glass needs cleaning on the inside. Not looking forward to that!
OUCH! :shock:
Don't know how much I've missed, but I've massively improved things. God it's painful on the coupe!
Has anyone got any suggestions for how to reach the bottom end? I don't fancy the idea of poking kitchen roll around with a big screwdriver...
13. Power steering seems very "strange". Suspect a dodgy pump
The steering's MUCH lighter and less "strange" when I hold the revs at 2000rpm when turning the wheel while the car's stationary. Am I right thinking the pump's knackered?
1. The clutch needs replacing
It slipped today while accelerating at high throttle in 3rd, NOT after a gear change, and nowhere near peak torque :shock: sh*t I really need a new clutch. Quickly. Just can't afford it though :( £525 from a trustworthy garage :cry:
Has someone got a garage, an interest in helping change a V6 clutch over a weekend, a taste for some beer, and some crashing space for a Saturday night? :lol:
I don't mind drinking (lots) of your Stella and crashing at yours 8)
Not sure about your clutch though :cheesy:
Sorry, not keen on beer (but I got everything else :cheesy: )
Would it make it 1,500 miles? :?
Just a thought - 13 - try changing the fluid?
