Peugeot 106
Re: Peugeot 106
thanks trem. lozz is kindly coming over to my house in the morning. he's gonna show me how to strip it off . once off we will nip down to general traffic (only 5 mins away) and get a replacement.
checked the shoes today and they seem really good so i will buy some brake cleaner and clean them off.
the park brake was also low. is adjusting the handbrake easy ? i'm sure lozz will know how 2.
any tips will help a lot 8)
Re: Peugeot 106
sirwiggum wrote:Looks similar to the Honda setup
https://www.hondapartsdeals.com/images/ ... .009.3.gif
Are these things all fairly similar?
My handbrake doesn't hold and I'll need to get it sorted before next MOT.
Tighten the cable up it can be done from the inside of the car on yours,
ithink you remove the ashtray to get at it,
5 min job that :wink:
Re: Peugeot 106
FarmerPug wrote:try putting it on ebay as an auction, if you get a few people bidding on it can jump up the price. Make sure to set a reserve though.
trouble with that is stupid %age ebay take when it sells.
Re: Peugeot 106
brilliant.
Re: Peugeot 106
Not unless you make up another ebay account, :lol:
iknow afew people thats done that and ebay had to whistle for there fees.
its a bit cruel but ebay can afford to lose afew quid A spose,
Re: Peugeot 106
with my luck on ebay. (the laptop) i think i'll pass on that idea lozz, but it has crossed my mind that had lol
my mates and i have previously done that :lol: :lol: :lol:
i#ll stick to the classified add that way i dont have to put up with winning bidders not turning us as well.
i'm gonna stick it on the auto trader as well 2moro if it passes re-test. its only 9.99 to put it in autotrader.
Re: Peugeot 106
Gary406 wrote:thanks trem. lozz is kindly coming over to my house in the morning. he's gonna show me how to strip it off . once off we will nip down to general traffic (only 5 mins away) and get a replacement.
they adjust up inside of the hub,
that will be easy enough to sort out,
did you soak that brake pipe where it goes into the cylinder with wd40 ?
Might be worth doing and leave it to soak over night if youve got some, just an idea,
they normaly untighten easy but ive had a odd Awkward one,
Re: Peugeot 106
i'm going spraying it now .
can i get at it with wheel on ?
will go look now and check back in 5 minutes for your reply 8)
Re: Peugeot 106
Gary406 wrote:i'm going spraying it now .
yup shouid be able to soak it in wd40 with wheel on ishouid think,
(just watch your eyes tho :roll: that stuff stings like a biatch ! :lol: )
Re: Peugeot 106
all done mate. it looks clean and clear anyway. 8)
Re: Peugeot 106
lozz 2moro mate can we adjust the drivers side as well.
mot tester said its a bit weak on that side as well . inside drum is dry on drivers side so will just need adjusting along with handbrake.
Re: Peugeot 106
Gary406 wrote:lozz 2moro mate can we adjust the drivers side as well.
no problem.
iwas going to sugest adjusting both sides its best way ithink. Both sides will be even then,
Re: Peugeot 106
ye and hopefully the brake pedal will be nice and firm cos you have to press it right down to get anything out of it.
having brake fluid on the rear shoes doesnt help :shock:
Re: Peugeot 106
Gary406 wrote:ye and hopefully the brake pedal will be nice and firm cos you have to press it right down to get anything out of it.
Spongey pedal wouid be normal for a Fubard cylinder ishouid think.
it shouid be easy to sort out,,
if all goes well 25mins tops 8)
sirwiggum
Re: Peugeot 106
Post by sirwiggum »
Cheers for the tip lozz, a wee job for the bank holiday weekend 8)
