window washers
stevenjp90
window washers
Post by stevenjp90 »
Hi,
Well after all this snow and freezing conditions, my window washer for the front has broken, I do know what is up with it though,
It seems a cap has popped of under the bonnet, meaning the water is spraying out of this, instead of the jets above the bonnet, I had applied presure to the opening with my finger, and it works how it should
as shown here.
I need to know what it's called (part desciption/no.) if there is a technical name for this 'window washer joint cap'. Also where I can get one of these from, I may have to take a trip up to the local scrappy for this.
Steve
Re: window washers
Hi,
Errr, you should be able to find something similar at a factors. What car is this on?
plod
Re: window washers
Post by plod »
Yeah, don't look like the one on service box
1999 D8.5 HDi GLX - Sold :(
stevenjp90
Re: window washers
Hmm Sorry I got the wrong forum, I have a 407 SW 2.0 diesel :oops:
not a 406
Sorry Guys unless you can still help?
jasper5
Re: window washers
Post by jasper5 »
That is known as a "Y" fitting, one way valve.
As Steve says you should be able to get one from a factors.
Re: window washers
Edit: Beaten to it by Jasper :lol:
Get the pipes plenty hot before you try pulling it apart...
Re: window washers
dont worry about it not being a 406, it doesnt even have to be a peugeot to enjoy the banter
