swapping the ecu on a d9 2.2 sri
can anyone tel me whats involved with this please? what do i need to swap as well as the ecu?
Current car - Ph3 1.8 306
Re: swapping the ecu on a d9 2.2 sri
you really are not happy at the moment with these problems, is the engine affected, or is it the interior stuff. Could be the bsi.
i'm at work at the mo, so i will at lunch.
want to ask questions while they are in my mind. i'm praying its not ecu failure!
i would check the footwell plug 1st, if you see any signs of corrosion like the post i sent you i would bet its them ,,, quite common on a D9 that problem
I Dont know any cure for the worry it was like the night my bsi played up coulnt go to sleep thinking about it. Cigarette perhaps.
right, just been out to the car and its seems to be 'getitng better'. the dash electrics seems to be returning, but it wont start still.Gary406 wrote:i would check the footwell plug 1st, if you see any signs of corrosion like the post i sent you i would bet its them ,,, quite common on a D9 that problem
HOW THE HECK TO I GET THE CARPET UP?
brute force
