D9 engine tray sagging?
no2lurch
Post by no2lurch »
went over some real rough ground today and caught the under engine tray on the loose ground.
should the tray be 'saggy' like this:
questions i have are:
-can i live without the trays?
-the front tray fits on top of the back tray so the back tray sort of forms a 'mouth' which i worry will open up (sagging down more) when i drive, so can i use some cable ties to close and secure this 'mouth'?
Current car - Ph3 1.8 306
Re: D9 engine tray sagging?
many cars d8s and d9s dont have them, personally i dont think you need them 8)
my trays been off the car for 6mths no probs so far,
ithink theyre needed - tho to stop water spraying up onto the belts & stuff :|
jamjar1383
Post by jamjar1383 »
my personal feelings on under trays are that if they didnt need them then pug would have never fitted them.
they do a few jobs, they are an aerodynamic thing for smother air flow under the car, they stop stones and the like from getting at the belts and causing any other damage , also even though they are only plastic the help protect the sump.
id leave it where it is if i were you, and yes you can use cable ties to secure it up a bit better, mabie a good idea to see if any of the screws are missing
d9 hdi 90 rapier estate
what about the 406s that arnt fitted ?
never known a stone to flick up and cause damage to a belt
my car doesnt have 1 and never has, but if it did i would probably leave it there and fix it up if it was broke ,,,
but its sumthing i wont be adding to mine 8)
On my suzuki jeep i had a tray, it rattled like mad, i ripped it out, and it got plenty of abuse off road, more abuse than a car will get in its life, and it kept going, so my opinion is they are unnecessary, ive none either on my 406, so dont worry yourself too much.
lozz wrote:I think they're needed - tho to stop water spraying up onto the belts & stuff :|
That's the one. Neither of my 406s left the factory with one, I never had any problems with the 2.1 D8 but this HDi seems more vulnerable to water being thrown up into the belts - occasionally, when I can't avoid it, I go through a puddle and then get the belt squealing, wipers on a go slow, heavy steering... bluddy car :roll:
no2lurch
Post by no2lurch »
the trays are both deffo secured to the car fine as they should, its just this gap. i think i will try to stitch them together wth cable ties.
CountryPug
Post by CountryPug »
Good idea to keep them on, mine sag in the middle too. Without them there isn't any protection against water splashing up around the belts like others have said, they'll help keep your engine bay cleaner especially at this time of year when there is salt on the roads and they keep the noise down quite considerably.
Present - 95' 405 GLX TD
Previous - 01' 406 LX HDi
no2lurch wrote:Image
That looks like the subframe is bent! VERY bad!
If it's just the plastic undertray, do yourself a favour and replace all the bolts with cable ties... :)
no2lurch
Post by no2lurch »
well i tackled this job yesterday. all the nuts came off ok, and i replaced some of the existing cable ties on putting it all back together.
i layed the 2 trays out on the floor and secured them both together with cable ties. i offered them back up to the car but they still were sagging a touch so i reinforced the join with some old thin ally brackets doubled up. its not sitting much better.
the trays are not the lowest point of the undercar now which i am happy about.
