Rear courtesy light as brittle as front?
I know I need a new courtesy light cover for the front as it will break on removal. Is this true for the rear too?
Re: Rear courtesy light as brittle as front?
if its a d8 i just pop the whole thing out simple
i also have some spares if yow need them
yep just done it now to a car i have hereCoxy wrote:On the back one you mean, you pop whole thing out?
do you want it?
Thanks but basically I just need to get to the bulb in mine. The front clear plastic breaks too easily on removal, but does the back bit pop out ok?
However maybe you can then help me with 2 parts; the front courtesy light lens cover thing, and maybe a recirc motor from the aircon? I'm assuming you're breaking a car there?
yep got a 16 valve petrol im breakingCoxy wrote:Thanks but basically I just need to get to the bulb in mine. The front clear plastic breaks too easily on removal, but does the back bit pop out ok?
got the front lamp you can have it complete.dont no where the recirc moter is give me a clue?
I rather think he'll be talking about this viewtopic.php?f=28&t=14276&p=133091&hil ... c*#p133091
okay thanks steve ill have a look tomorrow
farmers is a d9 i presume d8 are the same.
