I need to do mine ASAP as I found out after I snapped a spring the other day.
My uncle pulled one drum off becuase there was a rattling and there was next to nowt left on the shoes and a lip on the drums.
Now he had a bit of a problem getting the drum off as there was a lip on it.
Whats the easiest way to get the drum off when theres a lip? My Uncle just bashed the hell into drum and then leavered it off (he's a diesel fitter).
So whats the proper way to get the drum off when theres a lip?
Am I ok to remove the drill with a grinding stone on a drill? Or am I better off getting someone with a lathe to do it?
Is it worth regreasing the bearing before I put it all back together?
Bailes.
