Citreon (service-box)
As anyone got the equivalant to the service box for Citreon?
wondering if anyone has this, couid they check up on a part for us:
looking for info on a 2001 Citreon Piccaso, 1.6i (Crankshaft-pulley)
*Im trying to work out wether these are in 2 peices and they Break up like the ones on Diesels,
ive got a noise from the crankpulley from cold Chirping noise, which disapears over 2000 revs.
someone rekons the crank pulley on these is 2pcs, ialways thought it was Hdis that had this, :?
thanks inadvance,
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Re: Citreon (service-box)
Post by DiscoPol »
Lozz give us your VIN mate i will have a look, pm if your worried about the evils of the net :wink:
cheers mate,
much apreciated,
Vin : edited for Net security reasons,
DiscoPol
Post by DiscoPol »
Vehicle characteristics
Vehicle family XSARA PICASSO
AS RPO No 08718 FV 2 0228
Warranty Start Date 29/11/2000
Engine serial number 10 FX2D 0873828
Gearbox serial number 20 DL67 2380496
OPB P009
BER e2*98/14*0153*01
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XSARA PICASSO
SILHOUETTE FAMILY SALOON
TRIM LEVEL LOW / HIGH
ENGINE TU5JP INJECTION 100 HP
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EKQ - PAINT - WICKED RED
INTERIOR TRIM TYPE "HB" TALBERG CLOTH
UPHOLSTERY COLOUR "FZ"
GEARBOX (CHARACTERISTICS) BE4 J MANUAL GEARBOX
ENGINE (TYPE) TU
STEERING POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X18
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE CAST IRON
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
ENGINE (TYPE) TU
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
COOLING MOTOR RADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) STANDARD POWER
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN , 1 RATE 100W
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 15 X 64
WHEEL STYLE 15 INCH STEEL WHEEL
CLUTCH CABLE CLUTCH TAKING UP OF PLAY
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
DIFFERENTIAL (GEARBOX) STD IMP GEARBOX DIFF
TYRE (SIZE, TYPE) 185X65X15 H TYRES
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21
SUSPENSION NORMAL SUSPENSION
Body fittings
TOWBAR WITHOUT TOWBAR
WHEEL EMBELLISHER (STYLE) 15 INCH 7-SPOKE HENDAYE STYLE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
EXTERIOR ACCESSORIES NEUTRAL EXT HANDLES + SIDE STRIPS + DOOR MIRRORS
SUN ROOF FIXED ROOF
BUMPER TRIM DYED BUMPER STRIP
GLASS (APPEARANCE) TINTED
Interior fittings
SPEED GRADUATIONS GRADUATION MPH
CONSOLE WITHOUT CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG DOUBLE FRONT LATERAL AIRBAG
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
RADIO RECEIVER "RB2" RDS CASSETTE AUDIO SYSTEM
REFRIGERATION WITHOUT AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
Electrical
ALTERNATOR ALTERNATOR 70 AMP
BATTERY BATTERY L1 250
STARTER MOTOR CLASS 1 STARTER MOTOR
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
DiscoPol
Post by DiscoPol »
here you go bud :)
just realised the image cuts out no 20 which is the pulley
20
0515 N0
01
CRANK-PULLEY
6 VOIES-DIAM 146
6 WAY
Cheers,
theres no mention of the crankpulley on there,
iwill have to grab a haynes manual,
some of the info is incorrect to or may be my Pic has got a private plate,
and perhaps someones changed it from clutch cable too fluid. :lol:
85% of it apears to be correct tho,
thanks for your time in looking it up for us,
edit, just noticed the diagram, :oops:
that apears to be a solid crank pulley ?
or is it my eye sight, :roll:
