Banjo fittings
rwb
Banjo fittings
Post by rwb »
This got me thinking...
so the banjo and banjo-bolt are for making high-pressure connections.
But how do you attach the pipe to the banjo?
Anyway, given that you can attach a pipe to a banjo, the banjo is a second connection when you've already made one. So what's the point?
Re: Banjo fittings
Whats a banjo :?
lost me there mate,
do you mean jubilee clip?
rwb
Re: Banjo fittings
Post by rwb »
Here's a good picture: https://www.tyagiracing.com/products/14 ... -Hose.html
The banjo is the thing with the big hole in it, to which you attach your pipe.
The banjo bolt is hollow and has a hole in the side of it to let fluid in from the banjo.
Re: Banjo fittings
You mostly get them on the ends of brake & hydraulic clutch lines. Don't forget to anneal those copper washers if you re-use them! :cheesy:
