I will discount the a/c as it was my choise to get that up and running .
thrust bearing ,clutch and dmf though the latter 2 it didn't need
air dozer
blower motor
ignition switch
rear pads shoes and disc's
front pads and disc's
tyre's
engine mounts
engine cover securing bolts
fog lamps
bottom pulley timing belt and water pump
thats it i think
Thankyou Teamy a polite reply from a gentleman not like disco
with his sexual inuendo's , that boys been short of a damn good thrashing
when he was younger
puggy wrote:I will discount the a/c as it was my choise to get that up and running .
air dozer
blower motor
ignition switch
tyre's
engine mounts
fog lamps
thats it i think
& I thought mine was bad. Mind you, I'm not 2 years into mine yet & both MOTs have cost over £200.
To be fair half of that is ordinary service items that every car needs sooner or later. Otherwise, good going for an 11 year old car, and the good thing about an old Peugeot is that parts cost peanuts and they are easy to work on.
My neighbours 56 plate passat has just been towed home for the third time with it's third injector failure. Each time he's had to fork out £500 for a single injector. I told him his fancy German barge was too complicated and he should buy an old French heap instead. He didn't seem to see the funny side
5 on the trot, eh? I take it you've mastered the landings, then?
air dozer
blower motor
ignition switch
tyre's
engine mounts
fog lamps
thats it i think
same aux drive belt etc throughout? I'd get that swapped pronto in case it lets go, gets caught in the cambelt and 'Game Over'.
Oh & haven't we missed a boost pipe in there somewhere?
How is yours with a remap Puggy? May be up your way in a few days to take a gander at a replacement for mine. Just not sure if I can justify such a long trip as I generally buy within a 40 mile radius.
It's been great , had it done few months after getting the car and it's not
caused any probs. Better on fuel consumption , faster but the difference
in torque is the best thing .
