Fault discription from pp2000
carpingtaz
Post by carpingtaz »
Hi does anyone know what these faults mean and what they do:
Thanxs... :)
2001 2.0 HDI 110 Estate
Re: Fault discription from pp2000
can you double click on it, you will be brought into the bsi so to speak, then click on fault reading when in there, it will read more specific faults about this issue.
carpingtaz
FarmerPug wrote:can you double click on it, you will be brought into the bsi so to speak, then click on fault reading when in there, it will read more specific faults about this issue.
Don't think i could will try again 2morro just incase. just thought someone might have an idea.
what sort of car have you got (year, engine)
Is there a problem that you notice when using the car before plugging in the pp2000?
carpingtaz
FarmerPug wrote:what sort of car have you got (year, engine)
2001 2.0 hdi
no problems car runs fine, the only reason i put pp2000 on it is i got intermittent issue with the abs light on and abs fault on the display
but strangely there is no fault well according to pp2000 just came across these faults while looking.
try clearing them, i know when i did my first read with the pp2000 i got some odd faults.
carpingtaz
FarmerPug wrote:try clearing them, i know when i did my first read with the pp2000 i got some odd faults.
yeah i did that, came back the next time i used the car.
Did you get exactly the same list after clearing them?
The top 3 are indicative of a comms / van bus problem, may be worth trying a BSI reset.
