check this out,
Re: check this out,
someones going to definatley get Tinnitus driving that thing around.
I wonder would that work at removing dents
Re: check this out,
Fuckin nutters
How that side window hasn't shattered I don't know
Re: check this out,
they must be deaf
Re: check this out,
If theyre not they will be prematurelyomega wrote:they must be deaf
Re: check this out,
I think the vid is doctor'd
No way, they can be inside that car with no ear protection at that level - not without blood coming out their ears
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: check this out,
people sit near the speakers in night clubs /Raves,plod wrote:I think the vid is doctor'd
so id say its possible the audio system in the xantia is coshir
they might have some sort of ear plugs too,
Re: check this out,
although if its doing that to metal wouldnt your bones all be broken and shattered, some of it could be video editing.
Re: check this out,
It's real - see what it's doing to that girl's hair? I presume the windows have been replaced with perspex.
Re: check this out,
Darwin in action.
Re: check this out,
its a good test of build quality, try this on something slightly flimsy like a BX or 309, and compare it with an old merc or saab.
Re: check this out,
SO this car is supposed to go to over 160db, yet I'm led to believe levels over 130db can induce pain, hence my suspicion
Bring back my 406
- highlander
- PowerFlow Shill
Re: check this out,
This table is good:
But it doesn't mention the distance between the sound source and the listener, which is all-important - the decibel is a level of sound pressure, which falls away over distance. Also, to differentiate between other measurements recorded in decibels, you are meant to use the unit "dB(SPL)" which means "Sound Pressure Level".
There is a Wikipedia article (here) which does give a bit of distance-related information.
Also remember that decibels are measured on a logarithmic scale, so something that is 100 dB(SPL) is not twice as loud as something that is 50 dB(SPL).
More on Sound Pressure Levels can be found here:
http://en.wikipedia.org/wiki/Sound_pres ... sure_level
Re: check this out,
Very true. In fact + (or -) 3dB is twice (or half) as loud.highlander wrote:Also remember that decibels are measured on a logarithmic scale, so something that is 100 dB(SPL) is not twice as loud as something that is 50 dB(SPL).
Re: check this out,
Earplugsplod wrote:SO this car is supposed to go to over 160db, yet I'm led to believe levels over 130db can induce pain, hence my suspicion
