2.2 hdi
Re: 2.2 hdi
Registered on the road there is
670 Executive
416 GLX
204 SE
10 SRI
670 Executive
416 GLX
204 SE
10 SRI
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: 2.2 hdi
the 2.2 hdi seems to be rare over here ive only seen one in a scrapyard never anything for sale. apart from coupes
Re: 2.2 hdi
They do seem to be rarer in the saloon and estate than in the coupé. Judging by those numbers I'd suspect there were less than 800 that weren't coupés. Even less in just england.
Re: 2.2 hdi
There's definitely some GTX's too.....plod wrote:Registered on the road there is
670 Executive
416 GLX
204 SE
10 SRI
- waue1978
- HDi don't believe it!
Re: 2.2 hdi
Only 10 SRis - & 3 of those have appeared on Ebay in the past 12 months. Do wish I'd bought one of them & got the bits fixed now - reckon that would be a dead cert for a potential classic in years to come with that sort of rarity.
Re: 2.2 hdi
Are you sure there was a 2.2HDi SRi? I don't think there was, I'm thinking that's a mix-up of stats with the petrol 2.2 towards the end
- waue1978
Re: 2.2 hdi
There was. It's a proper rare breed too. Doesn't show up on Wisebuyers, What Car etc. but there have been 3 of them sold on Ebay in the past year. Put the reg number of one into confused.com when it was for sale & it shows up as SRi HDi (136).Welly wrote:Are you sure there was a 2.2HDi SRi? I don't think there was, I'm thinking that's a mix-up of stats with the petrol 2.2 towards the end
Think they may have been special order vehicles because I also saw a V6 SRi not so long ago that was apparently a special order for one of Peugeot UKs top execs.
Re: 2.2 hdi
Is there any problem areas with the 2.2 apart from the FAP? I was initially put off it because i thought they gave fuel pump trouble but that was the old 2.1 td
Re: 2.2 hdi
FAP, DMF, over boost problem due to air leaks in air hoses or the diaphrams in the various electronic valves that deal with the boost pressure - I have that issue with my 2.2 at the moment. Some people complain about electrical issues like the BSi etc. Like all modern common rail diesels high pressure pumps can fail etc. The cambelt change is an expensive job so make sure its been done. I am going to have to do mine in the new year - not looking forward to it.
The FAP is easy and cheap ish to deal with. Cost me 4 hours and £22 to defap my car properly - and to remap it aswell as removing the cat internals - well worth doing as it transforms the performance of these engines.
I am sure when doggy comes on or one of the other veteren 2.2 HDi owners can give you more detailed info on what to look out for.
Alex
Alex
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
Re: 2.2 hdi
406loon wrote:I am sure when doggy comes on or one of the other veteren 2.2 HDi owners
Apart from the FAP & the more complex vacuum system / variable geometry turbo, there's little else different about a 2.2, compared to Frank's 110 exec. The DMF & clutch are bigger, but cost about the same. Timing belt is to all intents & purposes the same job.
On the plus side, they're smoother, quieter & quicker, (particularly with 180 bhp remap).
2.2's are definitely thirstier and a band higher for road tax, but I wouldn't swap.
Re: 2.2 hdi
My mistake, that's 416 GTX's and NOT GLXdogslife wrote:There's definitely some GTX's too.....plod wrote:Registered on the road there is
670 Executive
416 GLX
204 SE
10 SRI
Bring back my 406
Re: 2.2 hdi
Coupe is showing up as around 1300, but there is the possibility the ones I listed "may" be coupe's due to listing inaccuranciessteve_earwig wrote:They do seem to be rarer in the saloon and estate than in the coupé. Judging by those numbers I'd suspect there were less than 800 that weren't coupés. Even less in just england.
Bring back my 406
Re: 2.2 hdi
Bring back my 406
- waue1978
Re: 2.2 hdi
Think there are a few GLXs too - the red one in Southampton a little while ago was advertised as a GLX & pretty sure it was right as it had the 4 dial dash whereas the GTX has 5.plod wrote:My mistake, that's 416 GTX's and NOT GLXdogslife wrote:There's definitely some GTX's too.....plod wrote:Registered on the road there is
670 Executive
416 GLX
204 SE
10 SRI
