Failed the MOT
Failed the MOT
Went to the mot test place today, car ready and it failed, because of the handbrake. :evil:
Ive got a set of new cables because everything else is not too old in terms of brakes, the cars booked in again on saturday.
Re: Failed the MOT
argh feck
sorry to hear that. :(
Re: Failed the MOT
The MOT man was probably being a big poof, let it be said that only he who apply'eth the handbrake of a 406 must have the arms of a Gorilla :shock:
It's not so bad Farmer, the 406 is pretty good come MOT time :)
Re: Failed the MOT
The handbrake was shite on the 406 ihad,
the lever had to be almost going thru the roof before it wouid hold,
it still passed on The mot test,
the Chap that tested it even stated, The handbrakes on these are Garbage,
leestudd30
Re: Failed the MOT
Post by leestudd30 »
Found that out myself, even in gear parked up it will still keep rolling, bloody thing!
Re: Failed the MOT
It was actually a woman who did the test today, and a very good looking woman she was, but she could have pulled the handbrake a bit more.
Everything else went ok at the test, they didn't do an emissions test, or check the wiper washers and i remember that getting checked last year.
Theres a new set of handbrake cables in now, took it to the mechanic and he let me help so we got all fixed there, there seems to be a more progressive action to the handbrake as opposed to nothing, nothing, nothing, a wee bit of braking. And he said he will check it before it goes for the test again which is good.
Re: Failed the MOT
Speaking of mot testing stations,
ive just refused a job at working at one,
after 5mins of the chap going on about some of his Anticts iwalked out the door, (iwished itook a dictaphone thingy in with me)
sorry carnt work for you fella didnt go down to well with him idont think :lol:
Re: Failed the MOT
thats a pity you didn't like it, an mot station wouldn't be the worst place to work, at least the ones here seem to be very good.
are they all government run in england or part of a mechanics garage?
plod
Re: Failed the MOT
Post by plod »
Hasn't the effeciency required for handbrake compliancy been increased, which given the notoriety of the 406 handbrake, makes it more likely our cars will fail on this point
1999 D8.5 HDi GLX - Sold :(
Re: Failed the MOT
efficiency required is 16% i got 15% :cry: .
Is a drum conversion from a d8 a possibility?
plod
Re: Failed the MOT
Post by plod »
Just rough up the handbrake shoes :lol: :lol: :lol:
Re: Failed the MOT
the shoes, they are still quite new, rough up with what though?
im surprised robert deniro managed to do that handbrake turn on dry roads.
plod
Re: Failed the MOT
Post by plod »
Well, maybe not the shoes, but the inside of the hub
I know it's maybe not the best analogy, but when I raced RC cars at national level, to improve the efficiency of the brakes, i'd get my Dremel, and score the surface of the pads and discs, and it made a dramatic improvement
It's not going to be a permanent solution, but if you scored the inside of the hub where the pads would work against the hub, it "should" improve the efficiency enough to get you through the test
Re: Failed the MOT
I usually rough up the inside of the disk/drum before the mot anyway.
FarmerPug wrote:Is a drum conversion from a d8 a possibility?
Or one from a D9 even. I can't see why not, I reckon the reason my back disks corrode is they're too powerful anyway.
Looks like the hub carriers are the same but you'll have to change the back plates - with the risk of damaging the bearings. Hydraulic lines, handbrake cables, looks like there's no difference in master cylinder though.
FarmerPug wrote:im surprised robert deniro managed to do that handbrake turn on dry roads
You're confusing films with reality again :P I've got that somewhere to make a animated gif but there's too much moving about & I couldn't be asked.
Re: Failed the MOT
to be honest the handbrake now is actually very good, not as good as my mums clios handbrake but enough to take the strain off the clutch on a hill. But would it be a wire brush attachment that should score the inside of the disk assembly.
Is that the problem with the handbrake it can't get enough pressure on the drum?
