battery question.on a 407
trem1
Post by trem1 »
Well ive gone out to the car again and its got a flat battery again. It did this 2 weeks ago and the RAC said it was the battery, which is under warrenty so i took it back to the shop, who among other things said they couldnt check the battery asit was only showing 11.5volts and needed to be charged overnight or a run with ALL electric's switched off for at least 500 miles(bullshit i know)
So ive left the car all week, went to start it and clik..
Checked the voltage on the battery and its showing 12.35 Volts, would that be enough for just a clik,and no start??
Re: battery question.on a 407
I'd expect it to have a go. What does it measure when you turn the key to "start"? When the battery died on my D8 it still measured something reasonable but had all the cranking power of a wet fart.
Check it right on the battery posts - one of the clamps might be loose or corroded.
trem1
Post by trem1 »
steve_earwig wrote:I'd expect it to have a go. What does it measure when you turn the key to "start"? When the battery died on my D8 it still measured something reasonable but had all the cranking power of a wet fart.
dunno steve im on my own and its dark, there speed clamps but are tight and i checked again on the bench before i connected the charger.
Any idea how to check the amps ??
Oh, if it's in the car you could put the headlamps on (gah, too much else on my mind, sorry)
If they light up, try starting it.
12.35 is fairly flat, (fully charged = 13.2 V. Fully discharged = 11.2 V.)
To hazard a guess, it looks like you have a charging problem / wiring issue. If you can re-charge it / get it going check the battery voltage, engine running, you should get about 14 V.
trem1
Post by trem1 »
dogslife wrote:12.35 is fairly flat, (fully charged = 13.2 V. Fully discharged = 11.2 V.)
the RAC man did all the checks and it was/is charging fine. just need ammo now as the factors shop seem to want to wriggle out of changing it
jasper5
Post by jasper5 »
If you turn the key and the dash lights go dim or flicker when you get the click the battery is the problem.
If you get just a click and no flicker with the dash lights you may have a starter problem.
You can't test a battery unless it is fully charged.
trem1
Post by trem1 »
jasper5 wrote:If you turn the key and the dash lights go dim or flicker when you get the click the battery is the problem.
yea dashlights/interior lights etc dim when the keys turned
trem1
Post by trem1 »
charged overnight and was 13.7v
took it back to carshop who tested it yet again and said its a good battery. He later rang me and asked me to go to ATS to use there meter to check which i did (and found out it was his mate :roll: ) And its a good battery, he did however give me a printout..see attachment, which says the start capacity is 65% i dont think that shows a good battery but hey what do i know.
So i came home and with my own meter on a warm engine IE: no glowplugs i got
12.79 whilst stood
9.77 whilst cranking
14.22 whilst engine running
your thoughts please
jasper5
Post by jasper5 »
Not sure that an overnight charge for a high capacity diesel battery is enough to fully charge it.
I usually charge diesel batteries at least 24 hours.
trem1
Post by trem1 »
jasper5 wrote:Not sure that an overnight charge for a high capacity diesel battery is enough to fully charge it.
the battery charger said it was fully charged ie: green light
If i put it on charge sunday evening till tuesday evening would that guarantee a full charge ??
jasper5
Post by jasper5 »
You would have thought so.
Something isn't right, can't tell without the car/battery to test.
