abbreviation
daley2450
abbreviation
Post by daley2450 »
Gents just reading stuff all over the site and as a newbe i have not got a clue on what some abbreviation are :oops: like bsi,d8 if some one could help out with a list of them that would be a great help.
cheers
Re: abbreviation
Hi mate,
D8 is a mk1 pug 406, 1996 -1998 ish
D9 is the facelift. facelift has differnt rearlights front lights grille etc, 1998 -03 ish
Bsi is behind the fuse box in d9s it controls parts of the car, like lights, stereo indicators the list goes on,
hope that helps abit :roll:
Re: abbreviation
Hope this helps (please, everyone feel free to correct and add to this):
BSI = Built-in Systems Interface (Boitier de Servitude Intelligent in French) - manages in-car features (auto lighting, cruise control, electric seat position memory, stores the mileage, manages the multifunction display)
COM2000 = computerised control system through which all auxiliary steering column inputs (i.e. auto lights, wipers, indicators, the trip computer functions, the horn, etc - but NOT the steering) are directed, interpreted, and passed to the BSI to be carried out. Only appears on fully-multiplexed cars from mid-2001 onwards.
D8 = not an acronym - just represents the internal design name for the Mk.1 406 (from 1996 through to mid 1999)
D9 = not an acronym - just represents the internal design name for the Mk.2 406 (from mid 1999 through to end of production in 2004).
DPF = Diesel Particulate Filter - an emissions control device fitted to 2.2 litre 16v HDi engined 406s from 2001 onwards
ECU = Engine Control Unit - manages fuel mixture, ignition timing, idle speed, valve control, etc.
FAP = Filtre à Particules - the original French name for the "DPF"
HDi = High-pressure Diesel Injection - PSA Group's name for their common-rail diesel engines
HPi = High-pressure Petrol Injection - a short-lived 2.0 litre direct-injection petrol engine used on the 406 range
HU = Head Unit - the stereo system fitted to the car
MFD = Multi-Function Display - the multipurpose screen that shows the date/time, CD/Radio station, sat-nav (if fitted), trip computer (if fitted), outside air temperature, and the settings screens for configuring your date/time, etc. Fitted to D9 cars; D8 cars get something a lot more basic.
MUX = multiplexed wiring - more modern approach to car wiring where signalling between various components is passed over the same set of wiring, rather than requiring completely separate wiring for each and every individual electrical item in the car. All 406s have multiplexed wiring, but cars from mid-2001 onwards are referred to as "Fully MUX" (introduced at the same time as the COM2000 unit).
PSA = Peugeot Société Anonyme - now referred to as PSA Peugeot Citroën, this is Peugeot & Citroen's parent company
VVT = Variable Valve Timing - improves the efficiency of an engine by changing the lift, duration, and timing of the intake and/or exhaust valves based on the rotational speed of the engine. Fitted to the ES9J4S V6 petrol engine and the EW12J4 2.2 litre petrol engine.
OdinEidolon
Re: abbreviation
Post by OdinEidolon »
highlander wrote:Hope this helps (please, everyone feel free to correct and add to this):
how to material - right there!
omega
Re: abbreviation
Post by omega »
dont forget
FFE
flipping french elecctrics
grasmere59
Re: abbreviation
Post by grasmere59 »
DMF=Dual Mass Flywheel
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: abbreviation
anyone for a resume on the XU / XUD / DHY / DW engine codes alphabet soup?
Re: abbreviation
Doggy wrote:anyone for a resume on the XU / XUD / DHY / DW engine codes alphabet soup?
I've got some of these codes up on the Wiki on the relevant engine description pages. Not 100% sure any of it is absolutely correct so could use someone with the knowledge to go look it over and edit where necessary.
daley2450
Re: abbreviation
Post by daley2450 »
Thanks to all for that spot on. :)
Cheers
jasper5
Re: abbreviation
Post by jasper5 »
One correction if i may?
BSI is Body Systems Interface.
Re: abbreviation
Box of Suspect Internals... :supafrisk:
FAP - http://onlineslangdictionary.com/meaning-of/fap
Re: abbreviation
excellent, 8)
next time isee a copper iwill shout oi you Fapper see if hes well educated or not :P
Re: abbreviation
& everybody missed FUBAR.
Tut, tut...
Re: abbreviation
There's always SNAFU... :wink:
Re: abbreviation
And we all missed BURMA, CHINA and NORWICH.
Edit: http://www.businessballs.com/acronyms.htm
Oooh, they missed one - Most Intelligent Customers Realise Our Software Only Fools Teenagers.
G'night!
